M6 fluid - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-16-2015, 08:38 AM Thread Starter
Quoted: 6 Post(s)
M6 fluid
Have you guys changed your M6 Fluid and if so what decent fluid did you replace it with?
johnfin is offline
post #2 of 8 (permalink) Old 07-16-2015, 08:42 AM
AlaGreyGoat's Avatar
GM # 88861800 Manual Trans Fluid
Larry
AlaGreyGoat is online now
post #3 of 8 (permalink) Old 07-16-2015, 08:44 AM
HP11's Avatar
Quoted: 24 Post(s)
I had all of the fluids changed at the dealership right after I bought it. They used GM Dexron III.
HP11 is offline
post #4 of 8 (permalink) Old 07-16-2015, 09:03 AM
Larry
Definitely what he said. It has the right properties to allow the syncros to work properly.
post #5 of 8 (permalink) Old 07-16-2015, 11:45 AM Thread Starter
Quoted: 6 Post(s)
Dextron III
Dextron is a given, but who makes a decent one with a additives. My stick seems to growl in every gear. I can bump the shifter up a bit and it stops the noise, not sure what is causing that.
johnfin is offline
post #6 of 8 (permalink) Old 07-16-2015, 12:41 PM
HP11's Avatar
Quoted: 24 Post(s)
I'll defer to svede to answer that one but, in my case, the fluid was changed by the dealership 6 years ago and they used Dexron III (no 't') and I have had no problems with noise, etc.
HP11 is offline
post #7 of 8 (permalink) Old 07-16-2015, 04:46 PM
I used dex6 in mine
zellerant is offline
post #8 of 8 (permalink) Old 07-16-2015, 05:15 PM
Originally Posted by zellerant View Post
I used dex6 in mine
You should NOT use Dex VI. It is NOT backward compatible with Dex III. You should also NOT use synthetic.
Frequently Asked Questions (FAQs)
fluid on exaust newtols2 2004-2006 GTO General Discussion 1 02-08-2012 03:32 PM
Fluid Servicing? symbian Service, Maintenance and Technical Discussion 5 04-04-2010 09:21 PM
Clutch Fluid canadianGTO 2004-2006 GTO General Discussion 5 11-15-2009 01:58 PM
Brake Fluid GNX231 2004-2006 GTO General Discussion 8 07-19-2007 01:55 AM
Synchromesh Fluid ModBoss2 Service, Maintenance and Technical Discussion 46 12-24-2005 08:46 AM
