Man. Tranny/Diff oil - Pontiac GTO Forum
post #1 of 11 (permalink) Old 01-10-2010, 05:20 PM Thread Starter
Need to change the tranny and diff oil (05, LS2 6 Speed) only 9K miles but as advised from the members here want to change it out. What is the capacity and weight I need for the axle and tranny? I know I'll need to add friction modifier but not sure how much of that to add with the diff oil. Any info appreciated.
Is it pretty easy to drain and refill and tips/tricks to help appreciated also?
Kirk
Corpus Christi, TX
khurst is offline
post #2 of 11 (permalink) Old 01-10-2010, 09:17 PM
jpalamar's Avatar
M6 you can get the fluid cheapest at Maryland Speed. 4.5ish quarts cap. I used Royal Purple w/ Synromesh
Rear figg needs less then 2 quarts that I just bought at Pep Boys cause it was local. Royal Purple rear dif fluid(already pre mixed with friction mod so its ready to go.)
There are other brands but I wanted to give RP a try. No issues yet with it and it is very easy to get ahold of.
04 GTO - sold
jpalamar is offline
post #3 of 11 (permalink) Old 01-11-2010, 05:23 AM
B-ville Goat's Avatar
+1 on the RP fluids. I have had them in my '05 for 3 years now with no problems. Some do need additional friction modifier in the rear, I did not and have had no issues. The SynchroMax is great stuff and will smooth out the M6's shifting real nice. I use 85w140 in my car, depending on your location and whether you drive the car in the winter, you may want to go with 75w90(I think that's what the weight is).
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #4 of 11 (permalink) Old 01-11-2010, 06:32 AM
jpalamar's Avatar
Its funny cause our owners manual states to use 75-140 for the rear but GM discontinued it and now states to use 75w90... I stuck with the 75-140 though.
04 GTO - sold
jpalamar is offline
post #5 of 11 (permalink) Old 01-11-2010, 02:47 PM
GM4life's Avatar
Kirk
Corpus Christi, TX
Search around on the forum you should be able to find the capacity and tips on how to change out the fluids. I'm using Dextron VI in my tranny and the stock fluid in my diff. I've used Royal Purple in my old diff, I can't say too much about it because it didn't stay in there long.
GM4life is offline
post #6 of 11 (permalink) Old 01-22-2010, 02:57 AM
I put Mobil 1 in my trans and it still has a hard 1-2 shift when its ice cold out, see my local, but seems to be butter smooth in other gears once warm. Put Mobil 1 in my diff, 1.6 qts, I believe, with Ford friction modifier since its a cone LSD. But perhaps I added the wrong amt as I get bad one wheel spin unless I'm rolling in a straight, then both grab...
MTUGTO is offline
post #7 of 11 (permalink) Old 03-26-2010, 03:12 PM
Is there any risk of damaging the reverse sensor when filling from here?
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is offline
post #8 of 11 (permalink) Old 03-26-2010, 04:25 PM
jpalamar's Avatar
Thats were I filled mine.
04 GTO - sold
jpalamar is offline
post #9 of 11 (permalink) Old 03-26-2010, 05:03 PM
GM4life's Avatar
Thats where you suppose to fill it.
GM4life is offline
post #10 of 11 (permalink) Old 03-26-2010, 05:58 PM
Why are their 2 fill plugs?
I've been driving with just the lower fill plug used for the last 40k miles.
Any damages?
Is the reverse light fill for lubricating the shifter portion?
My Youtube Channel
batmans is offline
Synthetic Diff Oil LS2FAST Service, Maintenance and Technical Discussion 17 06-08-2010 03:18 PM
65 GTO - limited slip diff oil? nikolas 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2008 02:51 PM
Tranny/Diff Fluid Change Time UdnUdnGTO Service, Maintenance and Technical Discussion 6 10-27-2006 11:37 AM
pontiac tranny to chevy tranny wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-27-2006 08:23 AM
