Monster Clutch - Pontiac GTO Forum
post #1 of 17 (permalink) Old 05-13-2010, 06:44 PM Thread Starter
Falco21's Avatar
Monster Clutch
Right now I have a stage 2 spec racing clutch and im getting ready to replace it with a monster level 2. I was probably gonna go with the C6 Premium Billet Package which includes the HD pressure plate, 12" dual friction disc, steel flywheel, pilot bearing and the alignment tool. Is there anything else i should replace or need? Thanx in advance
Falco21 is offline
post #2 of 17 (permalink) Old 05-13-2010, 07:44 PM
Bluegoat05's Avatar
personally i would go with a higher strength clutch because stage two is pretty low ecspecially if you are gonna keep up grading that car. monster has really cheaply priced clutches so go with a better one. a stage five monster is only two hundred more and can handle over 825hp.. thats what im gonna get, no sense in havin to get a better one later. and you may want to try going to a remote bleeder for your clutch and steel clutch lines.. also i would get and alluminum flywheel you gain like 8hp because of the weight savings. i just had a thought i wonder if it affects your torque negatively?
straight piped cat back, JBA shortys, JBA wires, AEM ca, and 421 slp tune
Bluegoat05 is offline
post #3 of 17 (permalink) Old 05-13-2010, 08:06 PM Thread Starter
Falco21's Avatar
thats an awesome point Bluegoat05....its definitely worth the 200 more bucks to upgrade to a much higher and stronger clutch...and yes i am planning on upgrading even more so getting the higher one would be much more logical ....and im not to sure on the negative affects on the torque, but thats a good question....keep me posted also when you get yours and when its done...i wana hear how it feels
Falco21 is offline
post #4 of 17 (permalink) Old 05-14-2010, 12:05 AM
87GN06GTO07IRL's Avatar
Don't forget to get a f-body slave cylinder. Way cheaper.
87GN06GTO07IRL is offline
post #5 of 17 (permalink) Old 05-14-2010, 06:52 AM
SANDU002's Avatar
I replaced my spec stage 3+ with a monster level 4. Call the people at monster and tell them what kind of driving you are doing and they will recommend the right clutch level.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #6 of 17 (permalink) Old 05-14-2010, 08:40 AM
jpalamar's Avatar
I would def do the slave and consider installing a remote bleeder. Also look into som SS lines while there. I plan on doing all this when my stocker fails.
04 GTO - sold
jpalamar is offline
post #7 of 17 (permalink) Old 05-14-2010, 08:57 AM Thread Starter
Falco21's Avatar
yea i was looking at the Monster Stage 4 premium package that comes with the slave cylinder....i was also gonna add the ss braided lines and a remote bleeder but i found this searching on the internet the other day just so that everything is basically upgraded...wat do you guys think of this adjustable master cylinder as well: TICKshift.com - Quick Shifting Six Speed Perfectionists
Falco21 is offline
post #8 of 17 (permalink) Old 05-14-2010, 09:07 AM
jpalamar's Avatar
I'd save the money and get a F-Body slave and transfer brackets.
04 GTO - sold
jpalamar is offline
post #9 of 17 (permalink) Old 05-14-2010, 09:11 AM Thread Starter
Falco21's Avatar
the F body slave as opposed to the premium package including the slave from monster?
Falco21 is offline
post #10 of 17 (permalink) Old 05-14-2010, 03:25 PM
Bluegoat05's Avatar
try marylandspeed.com they have monster clutches for a little cheaper..
LS7 clutch vs Monster Level 2 clutch POLGTO05 Drive train, suspension, alignment and brakes. 5 05-26-2010 07:18 PM
Monster Catfish roade Audio & Video Clips 4 03-13-2007 12:22 AM
What a Monster... Dragon 32 Racing and Kill Forum 5 01-29-2006 09:21 PM
