Muncie M-20 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-05-2018, 09:20 PM Thread Starter
Muncie M-20
Does anyone know the correct part numbers for a output shaft seal for a M-20 1971. Its a 32 spline output. Very difficult to get a consistent part number from any of the autocrats sites and I am seeing different inside seal dia. One I have found is the Timken 9449. Will that work?
wingmkr2 is offline
post #2 of 2 (permalink) Old 06-06-2018, 11:02 AM
Timken 9449 is correct, same as rear seal used for '67 up Turbo 400 and later 4L80E. I've always sourced Federal Mogul National seals, but for the late style Muncie 4spds, the seal was always purchased in a small parts kit with front bearing & sycro's
Welcome to the forum! Had 2nd cousins in Aledo for many years, they are retired, and have since moved down on Granbury Lake. Worked the old PATE swap meet near Cresson for 16 years, then for 3 years after the organizers ruined it & moved it up to the TX Motor Speedway Miss those great times and meeting new faces of the Pontiac faithful from all over.
64 Muncie ID budro 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 02-02-2017 06:14 PM
65 muncie trans mikey9743 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-30-2013 10:19 AM
1968 muncie m 21 par4n1 1964-1974 Tempest, Lemans & GTO General Discussion 3 01-31-2013 08:44 PM
muncie molaker 1964-1974 Tempest, Lemans & GTO General Discussion 0 06-18-2011 11:23 PM
For the muncie guru's... Backup 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-10-2011 11:55 AM
