need help taking brakes off - Pontiac GTO Forum
post #1 of 10 (permalink) Old 04-16-2010, 06:36 PM Thread Starter
740tank's Avatar
I have an 04 gto trying to replace a wheel lug how do I get to the back to change it out I already took the brakes off and tried hitting the back of the rotor with a 2lbs hammer while I rotated it and I got nothing
740tank is offline
post #2 of 10 (permalink) Old 04-16-2010, 07:26 PM Thread Starter
740tank's Avatar
nevermind I got it just needed to do it harder lol
740tank is offline
post #3 of 10 (permalink) Old 04-16-2010, 11:37 PM
Bfh.
post #4 of 10 (permalink) Old 04-19-2010, 09:57 PM
You need one of these. All break rotors will bow down to your absolute power.
Poncho Dan is offline
post #5 of 10 (permalink) Old 04-20-2010, 10:53 AM
jpalamar's Avatar
First time I took mine off it was a PITA. Lots of PB blaster and then ended up getting a big ass rubber mallet from Home Depot. Once I finally got them off. I used a wire brush to clean up al lthe rust on the hub, back of wheel, and rotor. Hit it with some brake cleaner to wipe it all down and used anti-seize. Now they pop off so easy. Just be sure to grease the back of the pads or you may squeal.
FYI, my DBA rotors actually have threaded spots on the rotor hat to help pop it off. It works really good. I don't know the size or threading of it off hand though.
04 GTO - sold
jpalamar is offline
post #6 of 10 (permalink) Old 04-20-2010, 10:58 AM
I've never used a three jaw puller for rotors. Just a B F H (not a rubber hammer). And I never hit the braking surface with the hammer unless the rotor is clearly junk. Instead I wail on the hub section between the lug nut. That will usually 'pop' it right off. It takes a steady hand though to swing a large hammer and not hit the wheel studs!
post #7 of 10 (permalink) Old 04-20-2010, 11:30 AM
jpalamar's Avatar
I think I have a slightly warped rotor from hitting the crap out of it. I have a break squeek that won't go away and only happens when the wheel hits the same position. I'm assuming a high spot on the rotor. I didn't know you could hit the hub without messing up the wheel bearing and all.
04 GTO - sold
jpalamar is offline
post #8 of 10 (permalink) Old 04-20-2010, 11:39 AM
I've owned a repair shop for 19+ years and never seen a wheel bearing go bad from removing a rotor. Some stubbern ones I've even used heat and an air hammer on.
On your squeek, look for that ridge of rust that sometimes forms at the outside and inside edge of the braking surface. Sometimes just knocking that off or worse case senero have then remachined can make the noise go away.
post #9 of 10 (permalink) Old 04-20-2010, 07:25 PM
I'm sure the puller will warp the crap out of them, but usually (in my situation) if a rotor is coming off, it's just plain being replaced, not refaced.
I also use a little 1-2" cutoff piece of 1/8" steel plate as a solid, even surface for the puller point if one is not available.
post #10 of 10 (permalink) Old 04-20-2010, 10:58 PM
GM4life's Avatar
Same exact thing I did except I soaked it in WD-40 and my Craftsmans rubber mallet and everything else you said. Great minds think alike
GM4life is offline
Taking the body off the frame. Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 07-28-2009 08:44 PM
Just Taking a Walk NJG8GT 2004-2006 GTO General Discussion 1 01-15-2008 05:41 AM
Taking off tires CrazyFace 2004-2006 GTO General Discussion 12 10-26-2007 01:10 PM
Taking me some vacation!!! dealernut The Lounge 10 03-23-2006 10:14 PM
taking apart the console HoldenGTO Service, Maintenance and Technical Discussion 3 12-10-2005 01:05 AM
