Need Opinions on MODS! - Pontiac GTO Forum
post #1 of 10 (permalink) Old 05-24-2010, 09:50 PM Thread Starter
As of now, I have a 2005 Midnight Blue GTO, M6, with a Vararam OTRCAI and 245/45/R17 Nitto 555R on rear. Very soon, I am going to purchase a DiabloSport Predator tuner. Will this put me in high 12's? And what other mods should i do? (i want to avoid headers but it "is" doable.) Thanks.
05topekaGTO is offline
post #2 of 10 (permalink) Old 05-25-2010, 05:15 AM
B-ville Goat's Avatar
The Nittos, Vararam, and handheld should get you in the high 12's no problem. Other mods you may consider are porting the intake and TB, some decent gains there, too. Headers, especially longtubes, will probably give you the biggest gain, though.
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #3 of 10 (permalink) Old 05-26-2010, 08:42 AM Thread Starter
since it looks like headers is the way to go, I might as well buy the slp version of the diablosport tuner b/c it comes with the Bobcat 455 custom tune for long tubes. And as for headers, looks like I'm gonna have to buy the SLP long tubes with highflow cats.
post #4 of 10 (permalink) Old 05-26-2010, 09:05 AM
jpalamar's Avatar
I wouldn't buy anything SLP. Don't get me wrong, they sell quality stuff, but they are way overpriced. So much nicer stuff avail for the same price. I'd look into Stainless Works or Kooks if I was going to drop that kinda money.
With you being an LS2, I'd really look into a ported intake mani. 15HP gains on a stock one wihtout a tune is very impressive.
Headers aren't REQUIRED for mild boltons but def wouldn't hurt. I don't have headers and I'm putting down 387(04 LS1) with a KNN intake, LPE GT2-3 cam(very mild), ported 243s, ported intake mani(worthless on LS6), ported TB, JBA catless mids and catback.
jpalamar is offline
post #5 of 10 (permalink) Old 05-30-2010, 07:41 PM
dms
dms's Avatar
If you have stock rear suspension, you are giving up a lot of torque due to the significant amount of movement in your back end.
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
post #6 of 10 (permalink) Old 05-30-2010, 08:50 PM
Subscribed!
miami photog is offline
post #7 of 10 (permalink) Old 05-31-2010, 12:58 AM Thread Starter
mike
dms
And your fix for the movement in the rear end is what? Maybe a Harrop diff cover and mount?
post #8 of 10 (permalink) Old 05-31-2010, 01:59 AM
That made a differance to me, also the cross-member bushings could be changed to a poly set from pedders.
motoristx is offline
post #9 of 10 (permalink) Old 05-31-2010, 10:57 AM
dms
dms's Avatar
Here are some suggestions:
1. OE springs are too soft. You need a 50-60% increase in rate for ideal rear coils. Plus OE coils are dropped alreaqdy from shipping and can be dropped as much as 1.25 inches. An ideal coil for drag racing is our Pedders 2589 drag coils. These coils are on most of the fastest independent suspension GTOs in the country.
2. Rear subframe bushings will firm things up for the rear cradle emmensely
EP1145 GTO X Member Urethane Bush
EP1168 GTO Xmemb sub frame connector
3. Adding a Harrop cover is awesome and is required really for 500hp at the ground. But if you do not hae the $500 or so for one, then you can add a differential bushing insert to make it a solid bushing
EP1157 GTO Diff Mount Insert
The rear inner control arm bushing is like a half bushing. There are nearly 50% voids in it. This allows a significant amount of movement of the lower control arms
EP7023 GTO Rear Control Arm Inner and Outer bush
These all help significantly and would be cheaper to upgrade than adding 50 plus rear hp
thanks
mike
dms
Michael White
dms is offline
post #10 of 10 (permalink) Old 06-06-2010, 01:30 PM Thread Starter
im thinking of doing putting a cam in my car. i've been looking at a Lingenfelter GT2-3 cam and it looks promising, can i do a cam before headers???
Needs Opinions on MODS 05topekaGTO 2004-2006 GTO General Discussion 8 05-17-2010 02:50 AM
Some opinions Ace 14 2004-2006 GTO General Discussion 12 06-28-2007 07:50 PM
Need Opinions GoatBoy37 Intake and Exhaust Discussions 5 12-31-2006 08:32 PM
opinions? GTO_400 2004-2006 GTO General Discussion 0 01-23-2006 06:09 PM
Opinions??!! 10 BEERS 2004-2006 GTO General Discussion 6 09-12-2005 06:51 PM
