New Rear Diff And Axle Carrier - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-10-2010, 11:44 PM Thread Starter
06goatm6's Avatar
Took the car to the dealer because the Limited slip wasn't doing its job, I had one wheel peel in my icy drive way. Talked to them today, they are replacing the entire axle carrier. From the driveshaft to the cv axles will be all new. It even came full of fluid he said haha. So that must have been an expensive bill, Thanks GM The bad part is I only have till March 23rd for anything else to go wrong, otherwise its gonna cost ME money next time. And now Ill have to drive it gently for 500 miles or more for the gears to mesh to each other Oh and I complained the steering wheel had some deformities in two of the spokes (almost looked like paint with runs in it) So Im getting a new steering wheel too HOORAY!!!
06 GTO IBM 408 Stroker-Sold
06 Corvette, Supercharged 607whp, RPM trans and Diff, RPS twin disc, Z06 susp, Dewitts Rad, Custom Fuel system
06goatm6 is offline
post #2 of 2 (permalink) Old 03-11-2010, 01:36 AM
AlaGreyGoat's Avatar
The plating is corroding and bubbling up. May want to check the
shifter knob closely. Mine is starting to bubble up between
the 2 and 4.
Larry
AlaGreyGoat is online now
Rear axle identification??? ylwgto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 11-06-2009 08:40 PM
Rear Carrier Axle Stamping Numbers Help!!! Lukeduk1980 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 07-23-2009 09:05 PM
Rear Axle Replacement DaveH 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 12-18-2007 08:20 AM
Rear axle Broke Toro Toro Service, Maintenance and Technical Discussion 26 12-05-2005 11:32 AM
GTO rear axle Redline Service, Maintenance and Technical Discussion 5 08-16-2004 11:42 AM
