new struts=alignment? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-10-2014, 05:54 PM Thread Starter
kirk44's Avatar
If I replace the front struts and coils with Lovell or Pedders keeping the factory ride height do I need to have the front end aligned? The car has 25,000 miles.
kirk44 is offline
post #2 of 4 (permalink) Old 06-10-2014, 06:35 PM
Yes.
GotTogO is offline
post #3 of 4 (permalink) Old 06-11-2014, 11:25 PM
While there replace the strut mounts and bearings and the radius rod bushings with caster adjustable ones. The radius rod bushings are a must on every gto. The stock ones are fluid filled and fail fast. There is no point to do alignment with defective bushings. Do some search on the radius rod bushings, there is even videos. If you get the caster adjustable ones give the car some positive caster.
Qnko is offline
post #4 of 4 (permalink) Old 06-12-2014, 05:38 PM
Don't forget bump stops. They're cheap and almost always trashed.
shocks/struts evanpatchay Drive train, suspension, alignment and brakes. 7 10-01-2012 10:13 PM
New struts and springs cmack111 Drive train, suspension, alignment and brakes. 2 10-12-2011 07:39 PM
Front Struts SPICERED2006 Drive train, suspension, alignment and brakes. 6 12-07-2007 08:33 AM
06 leaking struts ridgegoat 2004-2006 GTO General Discussion 4 03-19-2007 07:25 PM
Struts BILL06VA Drive train, suspension, alignment and brakes. 17 09-13-2006 08:46 PM
