Noisy shifter - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-08-2015, 08:28 AM Thread Starter
Quoted: 6 Post(s)
Noisy shifter
So I installed a new mcleod shifter and its noisy. Sounds like a bolt or knob is loose but its not. When I touch the shifter the noise goes away. I am thinking its the springs in the unit. Anyone have a problem like this
johnfin is offline
post #2 of 6 (permalink) Old 09-08-2015, 01:23 PM
Could be the knob. Are you using the stock one? Did you use a little RTV in it if you did?
post #3 of 6 (permalink) Old 09-08-2015, 03:03 PM
I put a piece of cork gasket between the handle and the shifter (gmm). Worked great.
GotTogO is offline
post #4 of 6 (permalink) Old 09-08-2015, 03:44 PM
Another thing I did with my GMM was used the black boot and used a hose clamp around the base to secure it. I'm sure that damps out any stray vibration and keeps dirt out too. The GMM has a round base that it works on though. Not sure if the Qwik Stick is the same.
post #5 of 6 (permalink) Old 09-09-2015, 09:27 AM Thread Starter
Quoted: 6 Post(s)
shifter
Dont think the boot will work
johnfin is offline
post #6 of 6 (permalink) Old 09-10-2015, 07:57 PM
It wouldn't be as slick as mine but you may still be able to put one on there. Definitely needs a clamp around the base to try though
noisy lifter... rickm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-16-2012 07:57 AM
noisy gto simmons68 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 12-28-2009 06:25 PM
noisy goat GTO6 2004-2006 GTO General Discussion 3 10-09-2006 08:23 AM
Noisy Brakes? scottsven Service, Maintenance and Technical Discussion 3 10-28-2004 04:16 PM
Noisy M6 n3tdud3 Service, Maintenance and Technical Discussion 1 10-23-2004 02:24 PM
