Only one left: Baer 13" GTO front BBK for $999 shipped @ PFYC.com - Pontiac GTO Forum
post #1 of 9 (permalink) Old 03-02-2010, 08:32 AM Thread Starter
Send a message via Yahoo to PFYC
Best deal for a front BBK in history? $999 shipped!!!
This very well might be the best offer anyone has ever made for a 13" big brake kit for your 2004 GTO, and we only have one in stock. No more will be offered after this one sells. This is our lowest price ever and includes free shipping in the lower 48 states and 50% off to Canada to boot.
Baer's incredible 13" Front Brake System provides high performance braking at a consumer-friendly price. Each front kit features two-piece 13"x1.25" rotors with PBR 2-piston calipers to produce solid performance and stopping power. This kit has excellent modulation, performance, and race-proven durability that make it an ideal street or track system.
ROTORS
The rotors in our kit are 13"x1.25", 36-vein directional 2-piece construction and are the very finest products from DBA.
These rotors are cast with DBA quality to Baer's specification of high quality iron, and additional material in the fire path, which increases the rotor's ability to withstand aggressive braking. A typical two-piece rotor sold by Baer saves, on average, five pounds of rotating mass over a comparably sized or OEM sized rotor. Each rotor is slotted, cross-drilled and zinc-washed to gain benefits such as the elimination of pad out-gassing, a more aggressive initial bite, the elimination of pad glazing, and improved wet weather performance.
BRAKE PADS
We include SBS Pro Touring Pads in this kit for excellent street performance. This compound is for ideal where extra brake performance and extended pad life is required. To ensure low-noise operation when used on the road, Pro Touring brake pads are equipped with noise reduction features similar to OEM pads. The friction level steadily increases during lower speed stops for predictable and confident braking.
NOTE: If you are planning to take your GTO to the track, please contact us for a wide selection of more aggressive compounds that we can recommend for any application including autocross and road racing.
CALIPERS
PBR Calipers are recognized by many as the finest floating calipers in the world. Their lightweight design and Pad Guided Caliper (PGC) technology have made them the #1 choice for many OEM applications. Because of PBR's widespread use, service components are readily available. Don't be fooled thinking PBR makes your average 2-piston calipers. In fact, on some vehicles they will perform better than some 4-pisons offered by the competition. Our calipers are done in a black anodized finish.
MOUNTING HARDWARE
Some manufacturers cut corners to maximize the use of pre-existing hardware products that may not be an exact fit. The hardware included with each Baer brake kit has been custom designed to insure a perfect fit. Baer designs and machines their own brackets, hubs, hats, spacers and more.
PFYC.com's Baer Kit includes everything you need for a complete front brake upgrade, including detailed installation instructions.
Please click below to go to the ordering page:
Baer Brake Kit for 2004 GTO
To see a full line-up of our new products for your 2004-2006 Pontiac GTO, please click here.
To see a full line-up of our current sales and specials for your late model GTO, please click here.
PFYC is offline
post #2 of 9 (permalink) Old 03-02-2010, 08:36 AM
Will this kit fit with stock rims?
post #3 of 9 (permalink) Old 03-02-2010, 08:43 AM Thread Starter
I'm pretty sure that the photo shows PFYC's old 2004 GTO with the same kit and factory rims, but I'll double check and post back if it is still available by the time I get the answer.
PFYC is offline
post #4 of 9 (permalink) Old 03-02-2010, 09:09 AM Thread Starter
I've put the fitment template up so you can check to be sure:
http://www.pfyc.com/supportfiles/gt4007template.pdf
usage instructions:
http://www.pfyc.com/supportfiles/gt4007tempinstr.pdf
PFYC is offline
post #5 of 9 (permalink) Old 03-24-2010, 03:39 PM
Does anyone here have this setup and what is their opinion? Also can this be used on a 2004GTO with 18' wheels?
pong is offline
post #6 of 9 (permalink) Old 03-24-2010, 03:43 PM Thread Starter
This was sold a few weeks ago
PFYC is offline
post #7 of 9 (permalink) Old 03-24-2010, 03:47 PM
Do you want me to move the thread to the boneyard?
post #8 of 9 (permalink) Old 03-24-2010, 03:49 PM Thread Starter
You can leave it, doesn't matter.
PFYC is offline
post #9 of 9 (permalink) Old 03-24-2010, 04:31 PM
Gotcha
pong is offline
10% discount on GTO Colgan front bras @ PFYC.com (1 week only) PFYC Exterior Discussions 1 01-20-2010 09:40 PM
Save $400 on our LAST set of 2004 GTO Baer BBK (front only) @ PFYC.com PFYC 2004-2006 GTO General Discussion 0 11-12-2009 09:38 AM
New board sponsor saying "Hi!" and 10% off EVERYTHING offer (PFYC.com) PFYC 2004-2006 GTO General Discussion 5 05-28-2009 08:59 PM
Complete Baer Brake Kit with 14" front & 13" rear rotors SLO 6-OH Drive train, suspension, alignment and brakes. 0 03-24-2009 09:35 PM
