Pedders Extreme Xa Coilovers Ob Hennessey Camaro - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-29-2009, 02:43 PM Thread Starter
dms
dms's Avatar
Pedders Xa on Hennessey Camaros
This is actually the third set of Pedders eXtreme Xa Coil Overs we have installed on the new Camaro, but it is the first set that we could take pictures of and play a little.
To start, here are pictures of the Hennessey Performance Camaro at stock height:
OE REAR
OE FRONT
Pictures of the Camaro after our Pedders eXtreme Xa Coil Overs installed:
FIRST SETTINGS
SETTING #2
.[/CENTER]
Some info about this Camaro:
Wheels are custom made by HRE, are are fairly light weight and beautiful
Tires are Pirelli Pzeros
Fronts are 275/40ZR20
Rears are 315/35ZR20
OEM ride heights were:
Front 680-682mm
Rears were 693-695mm
Please note the ride heights are measured from the lower wheel lip, thru center, to the fender opening. This is how we do it, which removes any tire influence.
The heights of the Camaro in the picture are:
SETTING #1 for VERY VERY serious driving
front: 646mm
rear: 635mm
SETTING #2 FOR VERY serious driving
front: 646mm
rear: 658mm
It looks like our coil overs have the ability to lower the fronts approx 2 inches and the rears approximately 3 inches. HOWEVER, this does not mean you will want to lower it that much. To put it into perspective, the front Xas are adjusted so the fender is between 5-10mm higher than the tread. This is a really sweet spot for this Camaro and the 275s in the front.
A special note to all: Running these size wheels and tires requires very close fitment and offsets. So working with the wheel manufacturers is important. I do not have permission to discuss the wheel offsets or sizes (I did not ask but I will)
thanks
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
post #2 of 3 (permalink) Old 05-29-2009, 02:44 PM Thread Starter
dms
dms's Avatar
Now some more info on the Hennesseey Camaro
Engine Upgrade: Picture tells it all!
Some Interior shots
Custom Seats
Custom Boost Gauge
My thanks go to all the members of the Hennessey Performance family for the support and assistance. You will see this Hennessey Camaro in a major magazine review soon!
THANKS
MIKE
DMS
Michael White
dms is offline
post #3 of 3 (permalink) Old 05-29-2009, 06:28 PM
silgoat05's Avatar
wow looks great!!!
Mods= Kooks 1-7/8,Catless Mids,Aem intake,Bmr strut brace,Bmr skid plate, Summit UDP,Corsa sport cat-back,160*stat,*Modern muscle tune*
silgoat05 is offline
1st Pictures & Description & Settings for Pedders extreme Xa Coil Overs dms Drive train, suspension, alignment and brakes. 1 02-20-2009 04:40 PM
705 hp and 717 lb-ft torque LS9 Hennessey HPE700 Camaro trev0006 The Lounge 12 01-10-2009 02:57 PM
2010 Camaro Facts AA GTO SP The Lounge 10 05-23-2008 08:51 PM
More on the 2006 Chevrolet Camaro Concept 05GTO In the News 9 02-26-2006 02:12 AM
Rising from the Ashes 05GTO In the News 2 12-17-2004 11:13 AM
