Pedders full suspension kit? reviews?? - Pontiac GTO Forum
post #1 of 15 (permalink) Old 08-03-2015, 01:45 PM Thread Starter
Hello! 2005 M6
has anyone gotten a full Pedders kit? Coils, bushings, sway and strut bars.
thanks
zainbabar is offline
post #2 of 15 (permalink) Old 08-03-2015, 06:25 PM
Seeing as Pedders USA has been bankrupt and gone for a while now it's unlikely you'll find one. There have been and still are other vendors with products just as good. I run a hybrid Energy Suspension, Super Pro, Lovells, Koni, Pedders and Hotchkis combo and am very happy with it.
post #3 of 15 (permalink) Old 08-05-2015, 07:09 AM
i got bit went to springs, bushings,koni adjustable shocks etc.andy at kollar took alot of money but its well worth it.all new gto owners should thank god theres people like this that make or supply parts for these cars.thanks andy.
papousr58 is offline
post #4 of 15 (permalink) Old 08-05-2015, 10:58 AM
It costs quite a lot to do a complete suspension. I did it in stages and most parts were gotten either on sale or a long time ago when they were cheaper and I still spent a little over $2,000 on parts. I did all the install myself which will save you a lot.
post #5 of 15 (permalink) Old 08-18-2015, 09:00 AM
I'm new here and have an 05 GTO for a daily driver. It has almost 100k miles and I live down a dirt road. I'm looking to replace almost all the suspension. I searched the threads here a bit before posting but I'd like a fresh recommendation on what is available right now. I'm not looking to lower the car and I still have the factory 17" wheels. Thanks in advance!
btrbandit is offline
post #6 of 15 (permalink) Old 08-18-2015, 09:27 AM
Lovells, Whiteline and Energy Suspension
post #7 of 15 (permalink) Old 08-18-2015, 01:45 PM
So far I'm thinking about going with King springs, stock in the rear and -.5 in the front, Whiteline strut mounts and sway bars, and Energy Suspension bushings. Would you recommend Koni or KYB for the rest, or maybe even an OEM brand? Depending on my (probably) bonus, I might even upgrade to some Harland Sharps or a cat-back. Thanks again for the input.
post #8 of 15 (permalink) Old 08-18-2015, 07:59 PM
Kings are pretty stiff. IMHO you can be too stiff on he street. It isn't the ride although that's a factor but traction. On a smooth track stiff is good. On an uneven street too stiff makes the wheels come lose contact. I have Koni shocks and set on stiff I can feel the back end hop over expansion joints. If that's on a curve you lose partial traction. That's why I like the Lovells (IMHO 200 drop all around is perfect). They are stiffer than stock but compliant. I can adjust the shocks/struts up a notch if need be but usually run full soft.
Don't know what you have done so far power-wise but both the HS and catback are extremely low bang for the buck if at all.
post #9 of 15 (permalink) Old 08-19-2015, 02:53 AM
I have kings on mine. Stock height rear and 0.5 drop front. They are stiff but i never had problem on a bumpy road and i mostly drive my car there (twisty canyon road). I guess keeping it stock height gives me good suspension travel and tires are always planted (lower springs usually have higher spring rates too).I also have koni adjustables on medium setting. I used to have a c5 that i bought lowered on some cheap coilovers and that car was so stiff that was scary to drive in the turns.
Qnko is offline
post #10 of 15 (permalink) Old 08-19-2015, 02:57 AM
You also mentioned sway bars. I don't think they are needed on the street. I got some hotchkis adjustable on mine. They were hard to install even on a hoist and i did not feel any difference.
Qnko is offline
Pedders USA suspension pissedgoat Drive train, suspension, alignment and brakes. 10 05-21-2013 11:06 PM
Bullet proof motor and Full Pedders supercar suspension ....what next wysocki396 2004-2006 GTO General Discussion 2 01-07-2013 10:57 AM
2004 GTO Pedders Full Repair Kit Ccas1382 Drive train, suspension, alignment and brakes. 4 11-05-2012 07:50 PM
pedders suspension AUTOSLIM50 Drive train, suspension, alignment and brakes. 16 05-30-2010 05:05 PM
pedders suspension yellow04gto 2004-2006 GTO General Discussion 1 12-31-2005 11:15 AM
