pot hole fix are front ends that tight - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-09-2009, 06:28 PM Thread Starter
I am purcasing a 06 from a friend with 18 k on it she hit a pot hole and bent front right rim getting that fixed but she drove car for a while and inner tire is wore out pretty good (need a new one) but i noticed it is actually hitting fender well a little when it turns are these front end and tires that close i,m hoping i need just a alignment and nothing bent ??? new to forum and the GTO
speedydog5 is offline
post #2 of 7 (permalink) Old 12-09-2009, 07:45 PM
FNG69's Avatar
Speedydog5 Check out HPP's Mar 2010 Tech on page 78. If anything needs replaced this is what you need to go too. Welcome to the forum! Les
FNG69 is offline
post #3 of 7 (permalink) Old 12-09-2009, 08:00 PM Thread Starter
what is HPP a magazine
post #4 of 7 (permalink) Old 12-09-2009, 08:34 PM
This may be the same article Les is talking about;
Pontiac Suspension Kits - High Performance Pontiac Magazine
05GTO is offline
post #5 of 7 (permalink) Old 12-10-2009, 02:32 AM
87GN06GTO07IRL's Avatar
Make sure you check the strut bushing.
87GN06GTO07IRL is offline
post #6 of 7 (permalink) Old 12-10-2009, 08:14 AM
jpalamar's Avatar
Better hope it isn't a wheel bearing as they are common to fail from impact. They are almost $500 from GM. I bought the aftermarket one for $100 and it sucks. Its worth the extra money to do that right if its the case.
If not, read up on the forum about bushings failing as they are common. You may be a little more damage then that, but it sounds to be simple stuff.
And enjoy your new toy!
04 GTO - sold
jpalamar is offline
post #7 of 7 (permalink) Old 12-10-2009, 08:32 AM
Decent article but they forgot Energy Suspension and Super Pro
Fiberglass Front Ends... TreySmith 1964-1974 Tempest, Lemans & GTO General Discussion 5 01-06-2009 07:36 AM
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Report Prompts Investigation Into Pontiac GTO 05GTO In the News 99 06-29-2007 06:13 PM
Simple Bumper Gap Fix Kanding Exterior Discussions 1 06-21-2006 10:42 AM
