Power steering issues - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-20-2015, 11:43 AM Thread Starter
johni53's Avatar
What would make the power steering unit (2005 gto) hard to use? Mine is stiff going around slow corners. The reservoir has fluid and there are no leaks that I can see from above and below. A friend said it's the cam I have that is affecting the way the pump is working. One fix is to go with electric but just wanted to hear some opinions. Has anybody experienced this after getting a cam that has a lope to it? Could that really be the reason? Thanks for any input.
1-7/8" ARH LTs, 3" Magnaflow exh.,Spec twin disc clutch, 402 stroker , Fast 102 w/Nick Williams TB, 1000 hp shaft & axles, cam, fuel & suspension upgrades. 500 rwhp, 484 rwtq
johni53 is offline
post #2 of 4 (permalink) Old 08-20-2015, 12:12 PM
Cam should not effect the power steering pump. Sometimes the bushings in the rack get varnished causing the rack to stick, especially in the mornings. I would try some LUCAS power steering conditioner and stop leak. Seen it work wonders with this issue. You'll have to remove some fluid from the pump.
post #3 of 4 (permalink) Old 08-20-2015, 05:02 PM Thread Starter
johni53's Avatar
Thanks, will give that a try.
johni53 is offline
post #4 of 4 (permalink) Old 08-21-2015, 05:42 PM Thread Starter
johni53's Avatar
Got the Lucas power steering fluid with conditioner, emptied the reservoir and poured the Lucas in and worked very well. Still just a little notchiness at slow speeds but feels way smoother; a huge improvement. I'm hoping it gets better the more I drive it. Thanks for the advice!
johni53 is offline
04' - Front suspension/steering issues amdoverclocker Drive train, suspension, alignment and brakes. 0 10-17-2011 01:00 PM
Power Window issues 901racer Service, Maintenance and Technical Discussion 4 05-15-2011 07:57 AM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
Steering wheel issues QSGTO Interior Discussions 4 04-18-2006 05:49 PM
