Power steering lines. Is this correct - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-09-2019, 12:36 PM Thread Starter
I’m using the old lines and pump is this correct? Looks a little off
Ken 66gto is offline
post #2 of 3 (permalink) Old 03-09-2019, 02:45 PM
Quoted: 13 Post(s)
I just put mine on according to the service manual. You have your pressure line on backwards. Lines should come off of the steering box at about 60 degrees. Both lines should come off the pump at about the same angle. In my picture, the return line still needs to be trimmed.
I would recommend replacing both of those lines. They look pretty bad.
Colorado67GTO is offline
post #3 of 3 (permalink) Old 03-10-2019, 12:28 PM Thread Starter
Thanks.
The crazy thing is I didn't remove the lines. They were like this when I bought the car.
Leaky tri-power fuel lines RunninLeMans 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 10-16-2017 08:06 AM
1966 tri power vacuum lines placement xkeots 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-24-2014 11:24 AM
Power steering return lines SWGOAT Drive train, suspension, alignment and brakes. 2 02-26-2012 04:05 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
