Power steering whine - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-06-2009, 02:11 PM Thread Starter
I have had a whine coming from my power steering for about a year and a half. I dosen't leak or feel sluggish just very annoying. has anyone else had this issue? and where could i get a better than oem replacement for it.
LordAnarchy is offline
post #2 of 8 (permalink) Old 07-06-2009, 02:32 PM
jpalamar's Avatar
OEM replacement is about $750. Google GM Part House.
I have one in my garage for an 04 if your interested. Took it out with30k miles. I upgraded to a Pedders close ration rack. I never had long tubes or anythong on it. Worked fine when installed.
I'll take picks if you want. I would sell for $140 shipped if your interested.
04 GTO - sold
jpalamar is offline
post #3 of 8 (permalink) Old 07-06-2009, 10:11 PM
GM4life's Avatar
How is your fluid level?
GM4life is offline
post #4 of 8 (permalink) Old 07-07-2009, 12:34 AM Thread Starter
The fluid seems to stay at a constant level. I usually check under the hood every couple of weeks to see how all the fluids are. I have had to add some but it was only a small amount over an 18 month span. Could it be that it's just worn out from strees?
post #5 of 8 (permalink) Old 07-07-2009, 12:41 AM Thread Starter
I really appreciate the offer J but I just spent $575 on a replacement differential and it would be a while bofore i could afford it. If something changes I could contact you. Thank you though, its cool you offerd.
post #6 of 8 (permalink) Old 07-07-2009, 06:55 AM
jpalamar's Avatar
No problem. Hope everything works out for you.
04 GTO - sold
jpalamar is offline
post #7 of 8 (permalink) Old 07-07-2009, 07:23 AM
Drain the fluid and replace with Lucas power steering stop leak additive. It's worked wonders on noisey pumps and racks before and it's only 10 bucks. well worth the money to give it a try.
Plus they use a blue `65 GTO in their adds!!
post #8 of 8 (permalink) Old 07-07-2009, 09:27 AM
jpalamar's Avatar
Gotta say it... There is a GTO in Transformers too
04 GTO - sold
jpalamar is offline
Power Steering Problem?? Devils3023 Service, Maintenance and Technical Discussion 13 01-20-2010 07:48 AM
Air in my power steering? spooled36 Service, Maintenance and Technical Discussion 10 06-25-2009 03:08 PM
65 GTO Power Steering Rag Joint Question WideTrack 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 07-23-2008 08:09 PM
67 GTO power steering questions Rangercrawford 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 10-21-2005 01:58 PM
