Purchasing rear springs, what other bits to get? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-07-2015, 05:42 AM Thread Starter
Icon Question Purchasing rear springs, what other bits to get?
Making a purchase of some rear springs in the near future, and wanted to know what other rear bits I can purchase along side the springs that will make a difference while the springs are getting replaced.
Thanks for the suggestions!
2006 GTO, Cyclone Grey
Mods: Magnaflow Exhaust
Forum Poster is offline
post #2 of 5 (permalink) Old 11-07-2015, 06:12 PM
Shocks of course but subframe and inner and outer control arm bushings make a difference. If you're having it done the bushings may be a challenge for some shops but I found it to be a reasonable DIY project as well as the springs and shocks.
post #3 of 5 (permalink) Old 11-08-2015, 02:48 AM Thread Starter
Svede, do you have any links you can send me for the bushings? I'm looking on Kollar racing, and other sites, but everything says its for the front?
I'm not sure if I'm even looking at the correct parts on my phone. LOL
post #4 of 5 (permalink) Old 11-08-2015, 11:31 AM
Red1970GTO's Avatar
You'll need to replace the Coil Spring Isolators. They are available from your local auto parts store.
If you're installing shorter, drop springs you should install Coil Spring Retainers. If you're simply replacing your old springs with the same length springs don't worry about retainers.
REAR CONTROL ARM BUSHINGS HERE: http://www.ss396.com/chevelle/3-3132G.html
Red1970GTO is offline
post #5 of 5 (permalink) Old 11-09-2015, 07:40 PM
was that link a typo?? it shows parts for a chevelle.
JoshLotterman is offline
Rear springs orelog 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 07-30-2012 03:49 PM
rear coil springs instead of leaf springs jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 01-02-2012 09:52 PM
rear springs butchjr15 Drive train, suspension, alignment and brakes. 1 04-21-2010 07:44 PM
rear springs matt68gto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 11 04-18-2007 06:19 PM
