Question on M20 tranny seals... - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-27-2018, 03:14 PM Thread Starter
Hey guys, I'm new here...been helping my buddy prep a numbers matching 70 GTO for certification in 2019 at the Gettysburg Show. It has an M-20 Muncie 4spd and one of the shift fork seals thru the side case cover is leaking. Has anyone tried to remove the side case cover without pulling the tranny? The tunnel clearance looks minimal and not sure if it will work. Tryin to save some work!!
Thanks in advance...Karl
LarrysGoat is offline
post #2 of 3 (permalink) Old 12-27-2018, 06:01 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
If you can get a Linkage shaft seal remover in there it can be done.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 3 (permalink) Old 12-27-2018, 06:45 PM Thread Starter
The seals are encased in a metal surround and are pressed into the boss on the case cover...I doubt the seal itself can be removed, but maybe worth a try. Thanks!
Need advice converting an Turbo 400 auto tranny to a manual tranny jimmy328 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-16-2012 04:35 PM
Muncie Transmission Question about an M20 Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 09-03-2011 11:16 AM
68 convertible window seals + bumper question xcmac26 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 01-03-2009 07:27 PM
pontiac tranny to chevy tranny wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-27-2006 08:23 AM
