Race or Street GMM Shifter?? - Pontiac GTO Forum
post #1 of 13 (permalink) Old 11-11-2006, 08:08 AM Thread Starter
which one should i get i like to street race and occasional drag strip!! but i cruise alot
Black Beast is offline
post #2 of 13 (permalink) Old 11-11-2006, 08:38 AM
bergenfelter's Avatar
Here is an email from JHP when I asked about the difference:
Hello John
Thank you for your enquiry.
If your vehicle is a daily driver with a little track work the "street"
shifter is the one for you, cost is $335 shipped, can be delivered within 7
days.
The only difference between both shifters is the shifter handle, both
shifter will give you the same firm precise/solid shift feel.
The transmission only needs to be lowered at the rear (tail shaft end) to
access the mounting bolts for the shifter assembly.
If you would like to proceed with your order, see below info.
Regards
Geoff Thuring
bergenfelter is offline
post #3 of 13 (permalink) Old 11-11-2006, 05:30 PM
LYNMUP's Avatar
What is the difference between the shifter handles? Is the price the same?
'05 QSM M6
LYNMUP is offline
post #4 of 13 (permalink) Old 11-11-2006, 11:11 PM
raven1124's Avatar
Send a message via Yahoo to raven1124
The street is about the same size in length as the stock shifter, where the race version is shorter.
raven1124 is offline
post #5 of 13 (permalink) Old 11-12-2006, 01:04 AM
LYNMUP's Avatar
They have the short one on JHP's web site. Kinda looks funny that short IMOA. So the one everyone raves about is the street version I presume.
'05 QSM M6
LYNMUP is offline
post #6 of 13 (permalink) Old 11-12-2006, 01:33 AM
raven1124's Avatar
Yep, the street is the way to go IMO.
post #7 of 13 (permalink) Old 11-13-2006, 06:09 PM
I have the race and am switching to street w/ Lou's short stick. The race shifter is too tall, too loud and too much vibration for me. You can buy the street handle from JHP {and add Lou's SS} and swap out the race handle if you are not happy with the race version {and vice versa}. I also got the Lou's ss threaded so I can replace the stock knob.
Hummer is offline
post #8 of 13 (permalink) Old 11-23-2006, 05:12 AM
basiclly the shifting mechanism is the same, but the race version comes with a different shaft, the street version uses the oem shaft and knob. the street version is quiet, the race version picks ups vibration and a bit of noise.
I have the street version with the oem shaft and knob.
That is the say to go. quiet , precise shifts.
If you are hesitaiting gettign the GMM , don't. It is the best for the GTO.
One of the first mods you want to do and you will not believe the difference in the shifting. Shift from second to third , shove forward and it goes to the right by itself , shove forward and you got third, it is the cats meow.
race or street is up to you.
if you do put it in , i would also at the time , change out the tranny fluid.
I put in the Royal Purple manual synthetic synchromax fluid. it also made the tranny quieter and smoother. you will need 5 quarts.
tranny takes on M6, 9.3 pints, or close to 4 and a half quarts.
can buy online or check your auto parts store , most good store have it.
oldsow is offline
post #9 of 13 (permalink) Old 11-23-2006, 09:54 AM
pickinfights's Avatar
Is there any difference beteween the GMM and the B&M??
pickinfights is offline
post #10 of 13 (permalink) Old 11-23-2006, 12:33 PM
as far as shifting i can't say about the difference between the two. There are guys here that have had B&M and took them out and put the GMM in, they would be the ones to get responce from. Before i made my choice I read alot of reviews on them both. Some were having trouble with the B&M , bolts coming loose or the shaft braking off.
I know the GMM costs more , but I wouldn't trade mine for nuttin. Cost only goes so far, sometimes ya gotta pay more for the good stuff, and I didn't want to have to buy one and then end up buying the other. Lots of $'s that way. SO I just got the GMM Street Version.
oldsow is offline
