Rattle coming from shifter boot - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-22-2009, 04:24 PM Thread Starter
Lately I have been noticing a fairly loud rattle noise coming from the boot of my 04 6speed. The rattle seems to be getting worse, I can stop the rattle by grabbing shifter nob tightly. I was wondering if anyone had any ideas as to what the issue might be, thanks!
goatfan2004 is offline
post #2 of 4 (permalink) Old 10-22-2009, 11:22 PM
Cobra126's Avatar
Your shifter mounting plate be loose. There should be 4 bolts holding in place. Naturally you will need to remove the boot to gain access.
Cobra126 is offline
post #3 of 4 (permalink) Old 10-23-2009, 04:29 PM Thread Starter
Thanks for the help, how hard is it to remove the boot?
post #4 of 4 (permalink) Old 10-23-2009, 05:08 PM
raspantienator's Avatar
Lots have had shifter rattle here. Check out the link below.
I had a GM dealer fix mine under warranty. If you have a an extended warranty, that may be the way to go.
https://www.gtoforum.com/f39/shift-kn...shifter+rattle
raspantienator is offline
A lot of heat and road noise coming from around boot area of shifter goatfan2004 Interior Discussions 8 06-26-2009 10:59 AM
Shifter rattle revisited raspantienator 2004-2006 GTO General Discussion 40 03-11-2008 03:16 PM
Shifter Makin Light Rattle? MonaroGuy06 Engine Discussions 6 08-27-2007 12:39 PM
Tight Shifter Boot? GM Kid 2004-2006 GTO General Discussion 16 06-28-2005 03:00 PM
shifter boot badtmpdgoat Service, Maintenance and Technical Discussion 11 01-24-2005 09:59 AM
