Rear Caliper bolt size? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-11-2010, 03:15 AM Thread Starter
harvotp's Avatar
Looking for new bolts that secure the caliper to the housing for a 2004 GTO. I got these numbers from the stealership 12mm x 1.5 x 41? The dealership doesn't have em' and cant get em' wonderful!
Would the 12mm x 1.75 x 45's fit?
or the 14mm x 2 x 45's?
I don't know what to buy I need help!
My caliper fell off the car going 80mph on the highway...dumb ****ing shop didn't torque the bolt to the right ftlbs and they slipped off causing my wheel to shred, EBC slotted and drilled rotor to shred, and my caliper is pretty much fubar'd. Now they can't find any bolt sizes from anyone to fit it.
Any help would be awesome!
'04 LS1 GTO
K&N intake, Magnaflow x-pipe, Bullet mufflers 2.5' pipes, B&M Ripper Shifter, SPEC Stage 2+ Clutch, Rear sway bar, EBC Sport rotors, RK Sport hood
harvotp is offline
post #2 of 3 (permalink) Old 04-11-2010, 09:56 AM
Lautinjr's Avatar
I usually purchase a grade 8 bolt from a hardwear store in the right size. In Vegas I use Mcfadendales they have the largest selection. Also a Jumk yard would probably have one off another car that would work.
Lautinjr is offline
post #3 of 3 (permalink) Old 04-11-2010, 01:42 PM
jpalamar's Avatar
Locktite them when you reinstall them. As far as fitting, don't buy the wrong size. Youm might be able to find the same bolt but longer and just cut it to size with a dremel.
04 GTO - sold
jpalamar is offline
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
12 Bolt rear G-Code72 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 07-31-2009 11:33 AM
Bolt size? 12mm x 1.5 or 1.25? specialk 2004-2006 GTO General Discussion 4 08-10-2006 10:02 PM
What size are the 17 inch rims and bolt pattern 01dakota59rt 2004-2006 GTO General Discussion 4 10-21-2005 01:12 PM
