rear clunking/clacking noise on 05 A4......... - Pontiac GTO Forum
post #1 of 35 (permalink) Old 07-22-2010, 12:11 AM Thread Starter
I have a 05 yellow A4 gto with 47,000 miles on it from the first owner. Got a this past saturday me and wife looking to trade in my trailblazer for a muistang gt or cobra for myself, stopped at a chevy dealer and saw this and loved it.
It runs great all kinds of torque and power man. Anyways I hear like a clunking/clacking noise from the rear seems like from the middle rear I think. Seems like it happens often when your dealing with the different combination of let the gas pedal out and apllying it again and using the brakes and letting it go and pushing the gas down again.
Like if I was to slow down to a crawl or complete stop and then release the brake and give it gas sometimes it will make that clunking noise like something has play and loose.
Anyone have any info I need to know? Does changing the rear diff fluids help with clanking/clunking loose play symptons? Seems like that will help the common whine the diffs make on these cars right? Thanks
pctek is offline
post #2 of 35 (permalink) Old 07-22-2010, 02:12 AM
Falco21's Avatar
you stated in the other post that you have the warranty. Just take it into the dealer and have them solve it. It could be a million and one reasons why its doing that. The best bet is since it is free, to let the dealer diagnose it for you. Best of luck
Falco21 is offline
post #3 of 35 (permalink) Old 07-22-2010, 07:02 AM
jpalamar's Avatar
Make sure to post the results when you get it fixed too! GM certified is a great thing.
jpalamar is offline
post #4 of 35 (permalink) Old 07-22-2010, 08:15 AM
Clunking and growling has been reported in the rear ends. I was a victim of it. The viscosity of the oil breaks down in time. Is this happening to you? If so >>
Internal clunking or growling from the rear diff:
https://www.gtoforum.com/f3/growling-...ng-rear-14102/
post #5 of 35 (permalink) Old 07-22-2010, 09:14 AM
I have it, maybe? I get a click-clack when I change gears, and can hear the diff loading and unloading, but I guess I'm used to it since my old RWD Pontiacs did that too.
It needs some fluid front and back, for sure... it's at 42K and I haven't touched it since I bought it.
Poncho Dan is offline
post #6 of 35 (permalink) Old 07-22-2010, 09:48 PM Thread Starter
This is also for "PONCO DAN" so the more I drive it Im getting the feel of when its happening. When Im driving along in regular constant speed on streets or freeway I hear nothing wrong, even when going over rought bumps, pot holes whatever on the streets the car is going over them smooth and no clanking/loose play type noises.
This loose play clanking noise happens when you brake at low speeds basically and then if you let go of brakes and where to hit the gas then it do that issue.
Yea the gm certified is good but if its a basic diff oil change I like to do it myself since its not to expensive. I thought diffs issues will be only the whines, howles, but bad diffs or oils can really cause something that sounds like it has come loose with play which makes a clanking/clunking noise I dont get it. Thanks
pctek is offline
post #7 of 35 (permalink) Old 07-22-2010, 09:52 PM Thread Starter
I think this saturday I might want to lift the back in of the car and see if I can see a issue, does anyone know spots in the back of car to lift with regualr small floor jacks? All I have is regualr size small floor jacks couple of them, floor stands thats it. Thanks
pctek is offline
post #8 of 35 (permalink) Old 07-23-2010, 03:37 AM
AlaGreyGoat's Avatar
SEE: GTO Lifting Locations.gif
(1) Suspension Contact Hoist Lifting Locations
(2) Preferred Frame Contact Lifting and Jacking Locations
(3) Spare Tire Service Jack Lifting Locations and Optional Vehicle Jacking Locations
(4) Optional Floor Jack Lifting Locations
Name:	GTO Lifting Locations.gif
AlaGreyGoat is offline
post #9 of 35 (permalink) Old 07-23-2010, 07:11 AM
jpalamar's Avatar
It isn't your fluids. Part of buying GM certified used is that they change all the fluids/filters before you buy the car.
jpalamar is offline
post #10 of 35 (permalink) Old 07-23-2010, 02:46 PM Thread Starter
Right I n otice the diff bolts where clean and looked recently removed. Like I said that clanking doesnt seem to be a diff oil issue like GTOJUDGE thinks it is.
SO I guess I'll investegate under the car. Thanks
pctek is offline
grinding/clunking noise in rear? SOLVED DeuceDaProdeuca Service, Maintenance and Technical Discussion 1 07-19-2009 02:42 PM
Growling/Clunking Noise Coming from the Rear GTO JUDGE Service, Maintenance and Technical Discussion 0 08-28-2007 01:08 PM
clacking noise over broken pavement silversport Drive train, suspension, alignment and brakes. 10 06-13-2007 10:25 AM
clunking/popping noise - new struts? dustyminpin 2004-2006 GTO General Discussion 2 09-14-2006 03:30 PM
Clunking noise when using e-brake 04m6_ca Service, Maintenance and Technical Discussion 4 04-29-2005 05:58 PM
