rear coil springs - Pontiac GTO Forum
post #1 of 34 (permalink) Old 01-23-2010, 12:37 AM Thread Starter
danfigg's Avatar
rear coil springs
Does anyone know if these spring would fit a GTO they look simular
danfigg is offline
post #2 of 34 (permalink) Old 02-01-2010, 01:26 AM Thread Starter
danfigg's Avatar
re
Well I will experiment with these springs and see how they fit our GTO I got my Fingers cross.-----Danfigg
danfigg is offline
post #3 of 34 (permalink) Old 02-01-2010, 06:40 AM
jpalamar's Avatar
I don't think you can just look at springs and say hey, they look the same so they work. They all have different spring rates, ect.. It isn't a simple yes or no. They may fit, but they may also not have a proper spring rate or even be strong enough to handle the weight, ect...
04 GTO - sold
jpalamar is offline
post #4 of 34 (permalink) Old 02-02-2010, 11:54 PM
87GN06GTO07IRL's Avatar
If your going to put springs on, put gto springs on, not something you dont know what it is.
87GN06GTO07IRL is offline
post #5 of 34 (permalink) Old 02-03-2010, 05:07 AM
Springs should be rated to the car they are in.
post #6 of 34 (permalink) Old 02-04-2010, 09:21 PM Thread Starter
danfigg's Avatar
re
Well first of all, the car will not know or care what spring is in it. There are three types of coil springs. double open end, open end- pigtail end, and double pigtail ends like our GTO. These springs are out of a car that weight's in at 4020 pounds with a with a weight distribution of 50f/50r 2010 pounds front and rear. Our GTO weight 3750 W/D 54f/46r 2025 pounds front 1725 rear. These springs are 10 inches tall extended like our GTO springs and look like they will be able to handle the rear weight of our GTO with not problems and no sag not by the picture but buy the info that I got from the vehicle they came out of and the seller of the springs. For 38 dollars shipped I couldnt resist. If they work I will share the info. If they dont I will resell them. I have a hook at FED EX for shipping no big deal. You dont have to spend hundreds of dollars to make your car ride good.-------Danfigg
danfigg is offline
post #7 of 34 (permalink) Old 02-05-2010, 09:34 AM
jpalamar's Avatar
Originally Posted by danfigg View Post
Well first of all, the car will not know or care what spring is in it. There are three types of coil springs. double open end, open end- pigtail end, and double pigtail ends like our GTO. These springs are out of a car that weight's in at 4020 pounds with a with a weight distribution of 50f/50r 2010 pounds front and rear. Our GTO weight 3750 W/D 54f/46r 2025 pounds front 1725 rear. These springs are 10 inches tall extended like our GTO springs and look like they will be able to handle the rear weight of our GTO with not problems and no sag not by the picture but buy the info that I got from the vehicle they came out of and the sell of the springs. For 38 dollars shipped I couldnt resist. If they work I will share the info. If they dont I will resell them. I have a hook at FED EX for shipping no big deal. You dont have to spend hundreds of dollars to make your car ride good.-------Danfigg
Enjoy wrecking your car, or best case it driving like crap. There is more too it then just weight and length.
04 GTO - sold
jpalamar is offline
post #8 of 34 (permalink) Old 02-05-2010, 05:06 PM
You had to buy the info?
post #9 of 34 (permalink) Old 02-06-2010, 06:31 AM
True, your car won't know what springs are on them. Your tires might. If the springs fit make sure your ride height is correct and the car maintains proper rear alignment or the money you saved on a set of springs may go towards new tires.
post #10 of 34 (permalink) Old 02-06-2010, 11:58 AM
I would also use extreme caution when high speed cornering to until you know for sure how the springs are going to react.
Installing front coil springs...need advice ponchonorm 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 15 08-19-2015 06:15 PM
Heated Front Coil Springs On '66 Gto take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-11-2009 10:16 PM
Coil Springs? ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-23-2009 04:06 PM
Rear Coil Spring mounting jasin 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 15 06-24-2008 10:05 PM
