Rear Control Arm Removal - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-09-2014, 10:46 PM Thread Starter
I'm most of the way through my complete suspension overhaul (Bushings, coilovers, and sway bars), but I am stuck at the rear control arm bushings.
When I removed the subframe bolt, the side of the cradle would not come down far enough for me to get the outer bushing bolt out. It's not hung up on the exhaust or anything else I can see, but I just do not have the clearance to get the bolt past the body.
Does anyone have any ideas what might be my holdup?
Mr.Rocket is offline
post #2 of 2 (permalink) Old 03-10-2014, 12:09 AM
I used a big bar to pry the arm down.
GotTogO is offline
Upper Control Arm Removal Oldeboy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 26 07-20-2016 06:51 AM
Rear Control Arm Bushings Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 05-28-2012 11:20 PM
Rear Control Arm Bushings cmack111 Service, Maintenance and Technical Discussion 0 10-28-2011 09:32 PM
Rear control arm bolts.....help!?!?!? mattg7890 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 07-02-2011 12:26 AM
Rear Control Arm Bushings boomer 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 05-26-2010 08:10 PM
