rear end oil? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-02-2010, 07:30 PM Thread Starter
Bluegoat05's Avatar
rear end oil?
hey guys i realize that this may be a dumb question.. but it seems i may have bought the wrong oil.. i got royal purple 75w90 will this be ok to put in the goat or will it be bad.. also i only have two quarts as this was all that particular auto zone had.. is that enough? it wouldnt be an issue but i live an hour away from a bussiness that has royal purple
straight piped cat back, JBA shortys, JBA wires, AEM ca, and 421 slp tune
Bluegoat05 is offline
post #2 of 2 (permalink) Old 05-09-2010, 08:51 PM
KyleGT05usmc's Avatar
you should be fine. i put in RP just recently, it already has friction mod in it. i think i put in 75w90 as well because an updated TSB recommends it from 75w140.
2 quarts is plenty. at autozone i bought a nifty pump which made refilling really easy. also you need a huge cresent wrench for the drain plug, its like 1 1/2"+
when refilling just keep pumping it in there until it starts overflowing from the fill plug then quickly plug it.
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 03:11 AM
04 rear end 740tank 2004-2006 GTO General Discussion 9 03-13-2010 11:08 PM
Rear End G-Code72 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 08-05-2009 04:05 PM
rear end Pontiac Tempest Cstm 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 08-18-2008 09:26 PM
Changing rear end oil??? TESLAFIED-GTO Drive train, suspension, alignment and brakes. 14 07-21-2008 04:50 PM
