Rear End out of alignment - Pontiac GTO Forum
post #1 of 7 (permalink) Old 04-10-2009, 09:45 AM Thread Starter
I had the rear end replaced on my 2005 GTO last fall. Is it possible that it could out of alignment? The passenger side rear tire is bald but the driver side rear tire is in good shape. Both tires are spinning so i know that the rear end is working ok. I would think that both tires would be wore out if it was out of alignment
Edzjk is offline
post #2 of 7 (permalink) Old 04-10-2009, 07:48 PM
mdbomgoat's Avatar
Could be, just make sure you take it to someone who knows what they are doing.
mdbomgoat is offline
post #3 of 7 (permalink) Old 04-10-2009, 08:11 PM
GM4life's Avatar
Make sure you take it someone that has the ability to align the rear cradle also. It requres a special tool.
GM4life is offline
post #4 of 7 (permalink) Old 04-11-2009, 08:57 PM
get the pedders rear camber bushing and dail it right in. It was the only way to dail mine in to the proper specs. The dealers specs have a range of 1-3 degrees, not good. Take it to someone who cares about GTO's and has the right tools!!!!!
dent is offline
post #5 of 7 (permalink) Old 04-13-2009, 05:05 PM
the only thing that is adjustable on the rear is the toe. camber and caster is not. a cradle alignment doesn't affect those
post #6 of 7 (permalink) Old 04-13-2009, 08:36 PM
GM4life's Avatar
Give DMS a ring or PM he's the man on this stuff. I trust only his word when it comes to suspension.
https://www.gtoforum.com/f39/definiti...oncerns-19058/
GM4life is offline
post #7 of 7 (permalink) Old 04-15-2009, 05:41 PM Thread Starter
I took it back to the dealer who replaced the rear end and they said they couldnt have knocked it out of alignment when they changed it. But they wanted to give it a four wheel alignment. I told them no. Now i dont know if it is out of alignment or if the camber is out. Is there anyone in Indiana who knows where i could take it? I live in Richmond
Edzjk is offline
Overdrive, rear end questions worldrocker77 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 10 03-27-2009 08:34 AM
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Rear Alignment Settings - Tech Help Please MeanGoat Service, Maintenance and Technical Discussion 2 07-25-2007 02:55 PM
Rear End rebuildable? cruiser787904 Drive train, suspension, alignment and brakes. 10 05-24-2007 09:42 AM
