Rear suspension issue - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-26-2010, 02:36 PM Thread Starter
My 04 Goat has a wierd feel to it when making hard right turns (left turns are fine). Almost feels like the body is shifting and then it grips and rides on a rail. Anyone else ever have this problem? I just put new wheels and tires on. The tires are 1/2" wider and now the problem is more noticable. Suggestions? Also, what would cause the right rear to petrude from the side of the car slightly farther than the left? Sagging Spring? Bad shock? Subframe? So confused. As u can tell I am absolutely new to this. Thanks for your help.
CYBERWITZ is offline
post #2 of 5 (permalink) Old 06-26-2010, 03:32 PM
Check your control arm bushings. The inners especially have had issues with an ear tearing off that holds the control arm. Also the rear shocks and springs on these cars are notoriously bad.
post #3 of 5 (permalink) Old 06-26-2010, 05:24 PM Thread Starter
Thanks. I appreciate the feedback. Any suggestions on replacement shocks and springs? Everything I have seen has been real expensive.
post #4 of 5 (permalink) Old 06-26-2010, 06:47 PM
ROBSGTO's Avatar
Personally I think King springs are the best,but I do have the more expensive Pedders big bore shocks.
Performance:230/232 .614 .602 114 cam,Kooks 1 3/4 headers/catted mids,Spintech,CSP ported intake/tb,UDP,tune by CSP.
Suspension:Pedders big bore shocks,GSR II struts,Lovells RR bushings,Kings 0 drop rears/20mm drop fronts.
ROBSGTO is offline
post #5 of 5 (permalink) Old 07-01-2010, 10:32 PM
dms
dms's Avatar
The GTO is plagued with bushing, spring, and damper problems. A really thorough inspection needs to be performed on the suspension. You should go to the Pedders site and look in the dealer locator section and see if you are close to a Pedders dealer
If I can assist you, would be glad to help
thanks
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 03:11 AM
Please help with suspension issue!!!! bilivegas Drive train, suspension, alignment and brakes. 3 06-03-2009 06:21 PM
Rear Susp. Issue hurleymotoxer118 Drive train, suspension, alignment and brakes. 3 06-02-2007 05:11 PM
Possible rear diff issue Aceofaces Drive train, suspension, alignment and brakes. 5 10-19-2006 09:58 PM
Suspension Issue PatrickNJ 2004-2006 GTO General Discussion 18 08-13-2006 01:05 PM
