Rear Wheel Alignment - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-31-2010, 04:49 PM Thread Starter
how much adjustment is there on the rear wheel alignment. the wheels need to be pulled in alot more. which way should u turn the adjustment nut on the strut rod?
Vettekid1992 is offline
post #2 of 2 (permalink) Old 06-04-2010, 09:21 PM
dms
dms's Avatar
the only alignment you can do on a OE GTO is rear toe. Camber is not adjustable without our rear eccentrics.
Traditionally rear GTO OE coils are collapsed from 1/2 inch to 1/5 inches. If you have too much camber, you need to put the rear ride height back to specs
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
What's your alignment settings for your suspension and wheel/tire setup? batmans Drive train, suspension, alignment and brakes. 4 03-17-2010 11:05 AM
Rear End out of alignment Edzjk Drive train, suspension, alignment and brakes. 6 04-15-2009 05:41 PM
Rear Alignment Settings - Tech Help Please MeanGoat Service, Maintenance and Technical Discussion 2 07-25-2007 02:55 PM
How much rear wheel HP kanibal Engine Discussions 3 01-05-2007 12:23 AM
wheel alignment popkorn77 Drive train, suspension, alignment and brakes. 13 05-05-2006 10:51 PM
