Replaced rear control arm, now parking brakes are not working - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-28-2016, 10:53 PM Thread Starter
So, as the title says, I replaced one rear control arm, and now my parking brakes are no longer working.
I chocked the wheels, engaged the parking brake and jacked up the vehicle, and both rear wheels can be spun.
I only touched one side of the vehicle, yet both wheels move freely.
Anyone have any ideas about what when wrong, and if so, how to fix it? I definitely need my parking brakes. My driveway is slanted to drain away rain, only now its just draining away my GTO!
FNM85 is offline
post #2 of 4 (permalink) Old 08-29-2016, 03:26 PM
GTO44's Avatar
Quoted: 39 Post(s)
When you put the replacement control arm in... Did it have a hub / parking brake assembly already? or did you take the original parts and swap it to the replacement control arm?
Sounds like it needs to be adjusted.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 4 (permalink) Old 08-29-2016, 11:06 PM Thread Starter
The control arm came with the hub assembly and brakes, but I switched out my original brake lines and rotor. I guess I need to adjust the shoes inside. I found a video online detailing how to do it.
I took my car in and had it realigned, and the mechanic peeled the boot off of my parking brake, revealed a set screw and tightened it down. I still need to adjust the shoes - the parking brake works, but my car rolls back about a foot before it fully stops.
FNM85 is offline
post #4 of 4 (permalink) Old 09-05-2016, 01:33 PM
jaybirdGTO's Avatar
Hope you get it fixed. Keep us posted!!
Jaybird
[/SIGPIC]
jaybirdGTO is offline
Rear Control Arm Removal Help tiretread Drive train, suspension, alignment and brakes. 8 04-11-2016 12:32 AM
Replaced Front control arm bushings GM4life Drive train, suspension, alignment and brakes. 3 10-17-2013 11:55 AM
Rear Drum Parking Brake Not Working jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 01-12-2012 08:21 AM
Rear control arm bolts.....help!?!?!? mattg7890 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 07-02-2011 12:26 AM
new master cylinder, rear brakes not working BlueMonkey 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 10-21-2009 09:27 AM
