Rt Rr Shock & Filler Tube - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-26-2010, 05:13 PM Thread Starter
Can anyone tell me if it is necessary to remove fuel filler tube in order to replace right rear shock? If so are there any tricks to make it easier than dropping fuel tank? HELMS says in MAY be necessary? Would like to know before I get started on tear down. 2005 gto
pags20 is offline
post #2 of 6 (permalink) Old 02-27-2010, 06:54 AM
It's not hard at all. Just pull back the trunk liner and reach over the tube. There's just one nut, washer and bushing on the inside. A deep socket, ratchet and extension are all you need.
post #3 of 6 (permalink) Old 02-27-2010, 07:03 AM Thread Starter
SVEDE1212,
Thanks for the info! That made my day! lol
pags20 is offline
post #4 of 6 (permalink) Old 02-27-2010, 07:10 AM
Take some care when tightening down the nut again. Make sure the bushing and stud are centered (by feel) as otherwise the stud may make contact with the car and make noise. Also don't over tighten the nut and crush the bushing.
post #5 of 6 (permalink) Old 02-27-2010, 09:07 AM
I found a picture for you showing now the driver's side would look. These are Koni shocks and they use two nuts which tighten against each other to lock them in place. Yours might use a locking type of nut. Note the bushing isn't crushed flat.
post #6 of 6 (permalink) Old 02-28-2010, 11:00 AM Thread Starter
That is some great info. Thanks again
pags20 is offline
rear shock question bobby326 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 02-08-2010 12:13 PM
