Rubbing in the rear... - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-22-2010, 10:39 PM Thread Starter
...That sounds kinda dirty....
Anyway, I just picked up an 05 that I've noticed rubs the back drivers side tire sometimes when I go over a bump on the highway or a rough patch of road. As far as I know its the stock suspension on there (47,000 miles) but I'm worried about ruining my tire. It's not something that happens a lot, just on rare occasions. What is my best solution for solving the issue and how much $ am I looking at?
Michael Henson is offline
post #2 of 8 (permalink) Old 01-22-2010, 10:59 PM
QUIKSLVR04GOAT's Avatar
My Goat does it too. Do you have stock rims on it? Mine does it rarely when i hit a big bump or i kick it down a gear and get into it. I have 19's tho. But if you got stock rims the sidewall may be too large to clear the fender when hitting a bump. look at the door jam on the driver side it will tell you the correct size. Some tire companies wont mount anything larger than 1 size + or -. I suggest a smaller sidewall or a less wide tire or Roll the fenders as the edge on the inner fender may start to tear into your tire. If you got it from a dealership they might have gotten a "great" idea to put on a set of new tires to raise the price on you.
Good Luck
QUIKSLVR04GOAT is offline
post #3 of 8 (permalink) Old 01-24-2010, 06:42 PM
ROBSGTO's Avatar
I'd get some aftermarket shocks and springs if it were me.I bought King springs for around $190 shipped if I remember correctly.You can get shocks from anywhere from $250-$300 depending on the brand.
Performance:230/232 .614 .602 114 cam,Kooks 1 3/4 headers/catted mids,Spintech,CSP ported intake/tb,UDP,tune by CSP.
Suspension:Pedders big bore shocks,GSR II struts,Lovells RR bushings,Kings 0 drop rears/20mm drop fronts.
ROBSGTO is offline
post #4 of 8 (permalink) Old 01-24-2010, 07:01 PM
These cars are known for strut and rear shock rub from strut bushing wear and rear spring sag. Have someone look at the alignment specs, then get something like a Pedders repair kit that fixes everything at once. Start from step one and check it out. It's fixable.
Jerry
deputycrawford is offline
post #5 of 8 (permalink) Old 01-24-2010, 07:37 PM
87GN06GTO07IRL's Avatar
Check your ride height. you ll probably need rear springs. If you get them and still have it, look into air bags and or fender rolling/cutting.
87GN06GTO07IRL is offline
post #6 of 8 (permalink) Old 01-24-2010, 09:45 PM
ROBSGTO's Avatar
Shouldn't have any rub with 245 tires unless you have aftermarket wheels with a very poor offset.If springs and shocks aren't the issue you would most likely need a cradle alignment to fix it.
ROBSGTO is offline
post #7 of 8 (permalink) Old 01-25-2010, 10:15 AM
Hello, one option for you is a set of our drag bags. They install inside your existing springs and will stiffen the spring rate. This will stop the tires from rubbing and will also help eliminate any wheelhop issues that you might have. Here is a link to our site. If you have any questions please let me know.
BMR Fabrication Inc.
Thanks,
Joe Kubiak
Sales / Tech
BMR Fabrication
813-986-9302 Phone
813-986-8055 Fax
[email protected]
www.BMRFabrication.com
BMR Sales is offline
post #8 of 8 (permalink) Old 01-26-2010, 12:40 PM
GM4life's Avatar
It maybe a combination of spring sag and cradle alingment.
GM4life is offline
245/45 17 Rubbing?? btchplz Wheels and tires 28 12-29-2010 04:39 PM
Rubbing Noise From Rear??? pwned 2004-2006 GTO General Discussion 29 05-28-2009 12:00 AM
Can a 275 series tire fit in the rear without rubbing? Slappy3243 Wheels and tires 16 03-20-2009 01:02 PM
rubbing sound rwilson831 Service, Maintenance and Technical Discussion 29 01-31-2009 12:36 PM
Rubbing on Right Turn emkiii 2004-2006 GTO General Discussion 7 02-27-2007 10:01 PM
