Same noise clunking coming from gearing - Pontiac GTO Forum
post #1 of 23 (permalink) Old 04-03-2015, 10:57 PM Thread Starter
Don't know what it could be will try to post video
I T8 I is offline
post #2 of 23 (permalink) Old 04-03-2015, 11:19 PM Thread Starter
I T8 I is offline
post #3 of 23 (permalink) Old 04-04-2015, 10:33 AM Thread Starter
Anyone
I T8 I is offline
post #4 of 23 (permalink) Old 04-04-2015, 11:30 AM
Quoted: 106 Post(s)
Get it up on the rack and rock the wheels back and forth with it in gear and figure it out.
Can't tell anything from a vid this will take hands on involvement.
Goat Roper is offline
post #5 of 23 (permalink) Old 04-05-2015, 06:31 PM
Drive shaft center carrier bearing or guibos
post #6 of 23 (permalink) Old 04-05-2015, 07:23 PM
Lemans guy's Avatar
Quoted: 55 Post(s)
clunking universal joints...
Lemans guy is offline
post #7 of 23 (permalink) Old 04-06-2015, 07:33 AM
That depends on if he put his post in the correct section. On a 2004-2006 GTO the stock drive shaft has guibos on the ends and not universal joints. It does have some at the center carrier bearing but then it needs a new drive shaft.
post #8 of 23 (permalink) Old 04-06-2015, 04:39 PM Thread Starter
Does anyone's goat make a clunking effect too ? Or is it just mine , the mechanic said it was normal but I don't believe this is normal
I T8 I is offline
post #9 of 23 (permalink) Old 04-06-2015, 08:24 PM
Lemans guy's Avatar
Quoted: 55 Post(s)
Maybe that mechanic has a normal clunking......that he hears...
that sure sounded like something was loose, ......svede was on it
Might want to check another shop.....driveline specialist
Shop can put a chassis ear on it to isolate it. It sticks on with a magnet or tie and transmits to the tech as he rides along with you driving....
He then pinpoints the clunking......normal or abnormal...as it were
post #10 of 23 (permalink) Old 05-01-2015, 08:20 PM
Do you feel it in the floor? Mine makes clunking too. 182k miles on it. I feel it in the floor when I take off from a stop. Have to reduce throttle until it accelerates enough to stop banging. Does not do it when cruising. The center carrier bearing on the drive shaft I know is shot. No more rubber in it. Don't know about the guibos. Plan to get under the car soon and scope it out.
nuclearnunberg is offline
clunking noise while turning trentwill83 Drive train, suspension, alignment and brakes. 3 12-16-2010 09:38 PM
rear clunking/clacking noise on 05 A4......... pctek Drive train, suspension, alignment and brakes. 34 08-15-2010 09:30 AM
Growling/Clunking Noise Coming from the Rear GTO JUDGE Service, Maintenance and Technical Discussion 0 08-28-2007 01:08 PM
clunking/popping noise - new struts? dustyminpin 2004-2006 GTO General Discussion 2 09-14-2006 03:30 PM
Clunking noise when using e-brake 04m6_ca Service, Maintenance and Technical Discussion 4 04-29-2005 05:58 PM
