SCSS engine & Tranny Mounts - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-20-2014, 05:10 PM Thread Starter
SIXO GTO's Avatar
Today I installed my Team SCSS mounts on my 13k 2005 m12 gto & I was wondering if anyone else has put these on their car ?? install was pretty easy on my frontend rack at work... question is HOLY drivetrain noise & vibration... I expected some but DAMN !!! the 1 thing I do like is my shifts feel way more precise & smooth but it feels & sounds like I have solid mounts hope they feel better once they get a few hundred miles on them... I have a weird vibration maybe driveshaft related idk ??? thinking of getting a driveshaft shop 1 piece to do away with the carrier bearing/gulibos set up ...I very rarely drive over 120-130 if at all so the 1 piece should work fine... the dealer installed b&m shifter works good but has been vibrating as of lately thinking about getting rid of it or seeing if the little Kevlar cup was installed on it as b&m says if not they tend to make a slight annoying noise once they wear alittle ?? any help or feedback would be great as im new to the gto's problems/issues slowly upgrading as the problems arise ! ! svede I know you always have something on your mind & hoping you can help me tomorrow is my drag bag install still squats 2 much on acceleration even with the new koni's & lovells 370 mm rear springs ( damned wheel hop ) ANY! WITH ADVICE I would really appreciate it ..
SIXO GTO is offline
post #2 of 4 (permalink) Old 06-28-2014, 12:12 AM
I have the hinson motorsports poly engine mounts and there is no vibration at all. Look it up and compare the pics. My car has a big cam and my friend was telling me that it will shake a lot but is totally fine. I had shifter noise when I put the mgw-p but its gone after 100 miles. Driveshaft vibration - I have G-force1320 one piece and I have taken it to 160 with no issues. I also have Koni (the adjustable ones) and King springs and the car squats just a little (shocks are not even on max setting).
Qnko is offline
post #3 of 4 (permalink) Old 06-28-2014, 12:56 AM
Steamwalker's Avatar
I would expect there to be quite a bit of vibration introduced when switching to poly motor and trans mounts. I'd never have them in my car. With that said, I've rode in a goat with SCSS motor and trans mounts and never noticed anything distressing about the ride quality.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #4 of 4 (permalink) Old 06-28-2014, 09:25 AM
I put Hinson motor mounts and a Revtech trans mount insert in mine and picked up quite a bit of vibration.
younggto is offline
Engine mounts HELP! Bigalsworth 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-27-2012 03:47 PM
SCSS Mounts SWGOAT 2004-2006 GTO General Discussion 3 02-13-2012 10:58 PM
WTB SCSS mounts SWGOAT 2004-2006 GTO General Discussion 0 02-05-2012 09:19 AM
Enigne & Trans mounts mebuildit Drive train, suspension, alignment and brakes. 1 09-11-2011 07:54 PM
Solid Engine Mounts ElementS8ing Engine Discussions 2 07-18-2006 10:03 PM
