Slotted Rotors? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-30-2014, 07:20 AM Thread Starter
Slotted Rotors?
Been doing a bit of research on the forum as to which rotors I should get next, mine are stock and quite warped. I do not track the car, its my DD but I figure when there is a chance to upgrade, why not? (plus they look cool). My question is, which slotted rotors are best bang for the buck? I figure x-drilled is overkill for the application... Ive been looking at quite a few of the posts on rotors on GTOforum, but a lot of them are from 06'-08' and outdated.
Links would be great!...
Thanks,
Evan
evanpatchay is offline
post #2 of 3 (permalink) Old 04-30-2014, 07:49 AM
SANDU002's Avatar
You might be able to find some used on this forum, ebay or LS1GTO. I have DBA T3's, but My 06 sees the road course quite a bit. EBC makes a nice one too. Can't go wrong with either one.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #3 of 3 (permalink) Old 04-30-2014, 08:46 AM Thread Starter
Nice, those look pretty good... Any issues doing the front rotors now since they need pads, then doing the rears later this summer? Helps the credit card also...
I was also looking at the x-drilled and slotted stop tech rotors (they are each around the same price). Seems as if they would work great and be much less expensive. Any thoughts? I just don't want to spend an extra 200-400 bucks to not feel any difference whatsoever...
Heres the link...
http://www.tirerack.com/brakes/resul...6&autoModClar=
slotted/dimpled brake rotors cracking motoristx Drive train, suspension, alignment and brakes. 3 11-18-2010 05:24 AM
Drilled/slotted rotors for 06 GTO's aaaaa5star Drive train, suspension, alignment and brakes. 16 08-25-2008 09:53 PM
Cross drilled and slotted Rotors sutliffhl21 Drive train, suspension, alignment and brakes. 10 09-02-2006 04:58 PM
