Squeaking noise - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-12-2015, 11:45 PM Thread Starter
Squeaking noise
sup everyone? when I turn on my goat there is a loud squeaking noise. not sure if its from the engine or it could be something to do with the clutch. every time I push the clutch in it goes away, when I let off the clutch the squeaking noise comes back. Would a new clutch be needed or would it be something else. did any of you guys ever have the same issue before. My car is an 06 gto with a manual trany. Thanks in advance
romeric is offline
post #2 of 3 (permalink) Old 06-13-2015, 09:35 AM
More than likely its the throwout bearing. While you're in there if the clutch hasn't been replaced in a while put in a slave with throwout bearing, pilot bearing, clutch assembly with flywheel and be sure to put in a remote bleeder.
post #3 of 3 (permalink) Old 06-23-2015, 04:59 PM Thread Starter
Yeah its the throwout bearing. Is it considered part of a clutch, because my warranty does not cover clutches. It sucks
romeric is offline
Squeaking evanpatchay Service, Maintenance and Technical Discussion 10 02-14-2013 05:43 AM
Squeaking Seat Lukemo2 Interior Discussions 5 01-20-2011 05:19 PM
Squeaking Noise Please Help Bday6262 Service, Maintenance and Technical Discussion 6 05-05-2008 07:47 PM
Squeaking noise from the rear djdonte Service, Maintenance and Technical Discussion 1 10-06-2007 03:09 AM
squeaking busyduck Drive train, suspension, alignment and brakes. 3 07-09-2006 06:45 PM
