ST300 to 200R4 Swap - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-05-2018, 05:29 PM Thread Starter
ST300 to 200R4 Swap
I'm going to replace the stock ST300 automatic in my 66 Lemans covertible with a 200r4 automatic. Any ideas, suggestions, pros, cons, etc would be greatly appreciated.
mjbiker2 is offline
post #2 of 2 (permalink) Old 09-15-2018, 12:25 PM
TexasT's Avatar
Make sure you get the TV cable set up and adjusted correctly.
Bowtie Overdrives | TV Made EZ
Move the crossmember back on the frame rails a bit, might have to drill some holes or your frame might have some already.
Depending on your rear end ratio, you might have a lugging problem in over drive but maybe not.
Let us know how it works out.
Rich
Real Estate's best friends are time and inflation.
TexasT is offline
powerglide to 200r4 Thurber73 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-03-2018 01:51 PM
st300 Bobcat 91 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 12-13-2017 01:23 PM
ST300 transmission CPL 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 10-22-2017 09:22 AM
st300 to th350 swap Thurber73 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 04-21-2015 05:50 PM
200r4 install drmgoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-20-2012 11:16 AM
