Standard drum brakes on a 1968 - Pontiac GTO Forum
post #1 of 1 (permalink) Old 09-18-2018, 01:39 AM Thread Starter
drg44's Avatar
My 1968 goat has standard drum brakes all the way around, it has the original Bendix master brake cylinder, the style that the top cover is held on by a single bolt. Does anyone have any knowledge if you can use that original part with a new power booster that would fit the Bendix it to get better braking power or should I just purchase a new master cylinder with a power booster? Thanks.
drg44 is offline
67 drum drum to disc drum-- old conversion Cudaboy_71 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 08-22-2017 07:15 PM
Front drum brakes or new disc brakes JTS GTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 01-23-2015 07:13 PM
Front Drum Brakes Diagram ChromeShopJoe 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 07-28-2009 04:06 PM
Converting Drum Brakes to Disc on 65 MikeMcGinn 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 22 04-21-2009 09:18 PM
From No P.S & drum brakes keoni1978 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 01-07-2005 05:29 PM
