Step down from GMM JHP - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-06-2015, 02:07 PM Thread Starter
Quoted: 6 Post(s)
What is the next runner up for a shifter. $500 is a bit much for a shifter.
johnfin is offline
post #2 of 5 (permalink) Old 10-06-2015, 09:02 PM
MGW-P, McLeod and Hinson are the only ones even worth looking at. B&M has been enough of a problem that I'd avoid it as well as Hurst. Lou's on the stock shifter has worked for some too
post #3 of 5 (permalink) Old 10-17-2015, 05:29 PM
I installed a B&M shifter in my 2005 GTO. It was about $180 and was quite an improvement over the stock unit. I also looked at the GMM and thought it was a lot of money for a shifter. I would highly recommend the B&M unit and I think you'd be happy with it. The throws are shorter and more positive now and the installation wasn't too much of a job.
fjbassplayr is offline
post #4 of 5 (permalink) Old 10-19-2015, 06:28 AM
johni53's Avatar
I've got a B&M and didn't like it until I had my transmission overhauled with bronze and carbon parts. Now it's shifting well, with no grinding in 2nd (synchro) and being able to shift into reverse with no problem. So far so good but only have about 300 miles on the transmission so time will tell.
1-7/8" ARH LTs, 3" Magnaflow exh.,Spec twin disc clutch, 402 stroker , Fast 102 w/Nick Williams TB, 1000 hp shaft & axles, cam, fuel & suspension upgrades. 500 rwhp, 484 rwtq
johni53 is offline
post #5 of 5 (permalink) Old 10-19-2015, 01:26 PM
The B&M suffers from bolting to the top of your old shifter and with only 2 bolts. That combined with the ball end snapping off made them a riskier choice. Some are still using them and from what I've seen more than others, some have been stuck on the side of the road.
next step mods chevyrida06 Engine Discussions 7 06-12-2010 10:28 PM
One step backwards crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-15-2010 09:15 AM
JHP GMM RIP Shifter (Race Version) Any issues? BlackSheep 2004-2006 GTO General Discussion 3 12-04-2006 06:06 PM
Someone gonna step up? Blueguy 2004-2006 GTO General Discussion 16 10-01-2006 10:25 AM
One step closer... Furyan 2004-2006 GTO General Discussion 3 09-19-2005 10:18 AM
