Strut mount bushings and Bearings - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-13-2013, 12:03 PM Thread Starter
NucciGOAT's Avatar
Hey guys, I searched around on this site and others and obviously found that the best things to replace first are the Radius Rod bushings and the front strut mount bushings/bearing.
But my question is, is it pointless to replace the front strut mount bushings and bearings with Whitelines/lovells (which ever on is cheaper) if I am not replacing the struts/springs? I mean I am planning on putting BC coil overs in the car when I have the funds, But I didn't know if it was a waste of time to replace these bushings without replacing the stock struts as well? Will I need an alignment if I do replace these mounts? Thanks
2004 yellow jacket M6: AEM intake, SLP LM2, 05/06 front brakes with DBA slotted rotors & hawk pads, B&M shifter, MSD wires, NGK TR55 plugs, Diablo predator tuned..
NucciGOAT is offline
post #2 of 7 (permalink) Old 12-13-2013, 12:51 PM
Steamwalker's Avatar
Replace at the same time.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #3 of 7 (permalink) Old 12-13-2013, 01:41 PM Thread Starter
NucciGOAT's Avatar
Thanks for replying, mind explaining your train of thought?
Sent from AutoGuide.com App
post #4 of 7 (permalink) Old 12-13-2013, 01:46 PM
You have to disassemble the strut assembly to replace the springs or the strut mounts so you might as well do them at the same time.
06/QSM/A4
SoCal Goat Club
post #5 of 7 (permalink) Old 12-13-2013, 01:49 PM
And yes, you should get an alignment after replacing the mounts, springs or struts as it will effect your alignment settings so you might as well do all at once.
06/QSM/A4
SoCal Goat Club
post #6 of 7 (permalink) Old 12-13-2013, 03:13 PM Thread Starter
NucciGOAT's Avatar
Oh so I actually have to get spring compressors and take the spring off the strut in order to replace those mounts and bearing?
I thought they might just be mounts on the body that the strut slid into or something. If I have to take the springs off and everything then yea your right it's not worth it, thanks for the insight.
One more question for you if you don't mind, I really appreciate the help. But in order to put in the crossmember bushings do you have to drop like the whole assembly? I remember reading an article in GMHTP where they modded an 04 goat and they put drag bags in and some massive bushings back there to eliminate wheel hop. I think they were the crossmember bushings, but they had to drop like the entire unibody/suspension to put them in. Or were those some kind of body bushing or frame or something?
post #7 of 7 (permalink) Old 12-13-2013, 06:45 PM
You do need spring compressors to replace the mounts. The mount sits atop the upper spring perch so you have to remove the nut that holds the mount as it secures the entire strut assembly together.
If I recall correctly, you can replace the crossmember (ie subframe) bushings one side at a time so you don't have to drop the whole thing.
06/QSM/A4
SoCal Goat Club
Body mount bushings orelog 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 11-08-2015 08:56 AM
Installed strut bushing and bearings ppxstnr Drive train, suspension, alignment and brakes. 0 06-01-2012 08:42 PM
Going to order soon some strut bearings, bushes for front end n need some help.... pctek Drive train, suspension, alignment and brakes. 0 05-15-2011 08:52 PM
Strut Mount Rubbing?? MonaroGuy06 Drive train, suspension, alignment and brakes. 1 02-26-2007 09:00 PM
