Suspension Torque Values for a 2004 - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-05-2010, 09:01 AM Thread Starter
pcviper13's Avatar
Hey Guys I need some help here. I have a 2004 M6 and I have the front suspension tore out replacing the bushings,springs and struts. My problem is that I can not find any torque specs to tighten it all back up with. I have done every bushing in the front along with the ball joints. Does any body have them or know where to find them ?
Thanks !
pcviper13 is offline
post #2 of 7 (permalink) Old 05-08-2010, 07:17 AM Thread Starter
pcviper13's Avatar
Has anyone here done their own complete front end rebuild ?
post #3 of 7 (permalink) Old 05-08-2010, 11:54 AM
GM4life's Avatar
Application
Specification
Metric
English
Control Arm Ball Joint Stud to Knuckle Nut
60 Nm
44 lb ft
Control Arm Rod Insulator Bushing to Front Frame Nut
23 Nm
17 lb ft
Control Arm Rod to Control Arm Insulator Bushing Nut
148 Nm
109 lb ft
Control Arm Rod to Control Arm Nut
103 Nm
76 lb ft
Control Arm to Front Frame Nut
98 Nm
72 lb ft
Front Suspension Support Brace to Body Nut
30 Nm
22 lb ft
Hub to Knuckle Allen Bolt
108 Nm
80 lb ft
Outer Tie Rod End Ball Stud to Steering Knuckle Nut
68 Nm
50 lb ft
Stabilizer Shaft Insulator Bracket to Front Frame Nut
27 Nm
20 lb ft
Stabilizer Shaft Link Lower Stud to Stabilizer Shaft Nut
50 Nm
37 lb ft
Stabilizer Shaft Link Upper Stud to Strut Bracket Nut
16 Nm
12 lb ft
Strut Rod Shaft to Strut Mount Nut
78 Nm
58 lb ft
Strut to Body Nut
55 Nm
41 lb ft
Strut to Knuckle Nut and Bolt
First Pass
85 Nm
63 lb ft
Second Pass
100 Nm
74 lb ft
Third Pass
90
GM4life is offline
post #4 of 7 (permalink) Old 05-08-2010, 12:01 PM
GM4life's Avatar
Did you do the control arm bushings? How did you press those out?
GM4life is offline
post #5 of 7 (permalink) Old 05-08-2010, 01:17 PM Thread Starter
pcviper13's Avatar
Hey thanks for the torque specs. Now I can get it going back in.
I did change the control arm bushings along with the rear radius rod bushings.The Bushings were pressed out at a friends shop while he did the balljoints.
I replaced the control arm bushings with the Pedders race spec steel sleeve bushings that were pressed back in. They were the hardest to get in.
Thanks again for the specs !
post #6 of 7 (permalink) Old 05-08-2010, 08:05 PM
chilliwhiggerE's Avatar
Location: Hollywood, Florida originally from Pittsburgh, Pa.
I used a short 1/2in extension on one end and a large deepwell impact socket on the other and drew them together with a large C-clamp. The 1/2in extension fit inside the bushing and the deepwell impact gave it something to travel into. If your 1/2in extension doesn't fit you might be able to shim it up with a washer.
BTW the Radius Rod Bushing Torque is 109lbs-ft on the 24mm bolts.
chilliwhiggerE is offline
post #7 of 7 (permalink) Old 05-12-2010, 09:50 AM Thread Starter
pcviper13's Avatar
Thanks for the help guys ! Now it is on to the back of the car.
torque converter NEXSTAR7 Drive train, suspension, alignment and brakes. 5 04-13-2013 09:59 AM
Suspension Airbag Setup Vs. Regular Suspension Setup MJGTOWISH 2004-2006 GTO General Discussion 8 06-20-2006 09:23 AM
Torque Specs toms66 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-09-2006 08:18 PM
Torque Management ??? Toro Toro 2004-2006 GTO General Discussion 16 01-05-2006 08:13 PM
05 residual values drmustang 2004-2006 GTO General Discussion 0 01-11-2005 04:32 PM
