Suspension Upgrade - Extra Parts? - Pontiac GTO Forum
post #1 of 19 (permalink) Old 07-14-2014, 11:32 AM Thread Starter
Last year I ended up replacing several suspension components, both in the front and rear. I installed KYB front struts and rear shocks as well as the Kollar Racing "No Rub Kit" which includes front radius rod bushings, strut mounts W/bearings and bump stops. The picture attached is what is left over.
At first I didn't put much thought into the "leftovers" but now I am curious as to what components I have left here. I have been getting random noises over bumps in the road etc and would still like to tighten the suspension up a bit still. Are these rear shock bushings?
FYI, in the near future I will be installing brakes and rotors with Lovells rear springs at stock height so I will have the suspension accessible at that time. Please let me know what I have here and maybe other considerations... All the pieces are identical except for the washers on the right, which are different thicknesses.
Any input is appreciated!
Thanks,
Evan
evanpatchay is offline
post #2 of 19 (permalink) Old 07-14-2014, 02:09 PM
The top three on each side look like the rear upper shock hardware and the other extra watchers might be the leftovers from the from radius rod mounts. Did you reuse the rear shock hardware?
younggto is offline
post #3 of 19 (permalink) Old 07-18-2014, 09:48 AM Thread Starter
I might have... That would make sense, although its too long ago for me to remember at this point. I am wondering if I should pull them out and install the new bushings because the rear sounds a bit noisy over bumps.
post #4 of 19 (permalink) Old 07-20-2014, 09:35 AM Thread Starter
Does anyone have a picture of their rear lower shock mount assembly? At this point I am sure the hardware goes there and I have it set up incorrectly... What I have works but it still bothers me because I am very particular just like many of you...
post #5 of 19 (permalink) Old 07-20-2014, 10:29 AM
Of course I do. That's not it. The lower bushing is part of the shock and the hardware is just a long bolt and big washer. That looks like the top shock hardware. I would recheck the nut in the trunk. You can under-tighten or over-tighten that nut. Also the rubber can be offset allowing the bolt to contact metal.
post #6 of 19 (permalink) Old 07-21-2014, 07:39 AM Thread Starter
After exploring the shock mounts it seems that there are two potential issues.
1.) The rubber bushings in the top rear shock mounts seem very squished. I dont know if this is normal, or if I should be replacing them with the donuts in the thumbnail that I uploaded.
2.) There is a 1/4'' gap or so in the rear lower shock mount. This would be between the driver side and the left side of the shock if your looking at svedes picture.
These issues arent huge, but I am getting a lot of noise over bumps and I am trying to make everything feel "solid"
post #7 of 19 (permalink) Old 07-21-2014, 08:40 AM
I know with my Koni shocks there was a risk of over tightening the top nut and squish the bushings out. I ended up with Super Pro bushings which had a better stepped area to retain the bushing in place. I'd work on that area. The lower like I said is part of the shock. There should be a steel sleeve inside the rubber part. That gets sandwiched between the washer and wheel arm holding it in place.
post #8 of 19 (permalink) Old 07-21-2014, 02:36 PM Thread Starter
Where did you buy your bushings? Dosent look like super pro sells direct...
post #9 of 19 (permalink) Old 07-21-2014, 08:07 PM
They used to be distributed by a local company and I just drove over and picked them up.
Google Super Pro and they have a distributor map for the US
post #10 of 19 (permalink) Old 07-21-2014, 09:54 PM
Steamwalker's Avatar
They are all interchangeable, Whiteline, Lovells, Pedders, Superpro, etc as far as upper shock bushings go. I had Whiteline but I removed them because they provided too much NVH in the rear for no benefit.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
Suspension Upgrade! Falco21 Drive train, suspension, alignment and brakes. 30 04-25-2011 05:03 PM
Suspension upgrade knaletko Drive train, suspension, alignment and brakes. 11 05-03-2010 02:12 PM
Extra Parts Inside the Door noz34me Service, Maintenance and Technical Discussion 12 03-31-2006 02:52 AM
