Swaping my 04 diff with an o5 help!!! - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-03-2009, 08:10 PM Thread Starter
I purchesed an 05 diff and found that the yolk has 4 bolts as opposed to my 04's 3 bolt pattern. Is it possiable to swap the yolk? I am trying to avoid having to buy the rubber boot for the 05 and if I have to will it bolt up to my 04 drive shaft. I have a window of 22 hours to do this swap so any advice will be supper helpful. and yes i know, why would i start taking this apart without knowing what was entailed. my bad but please help. Thanks in advance
LordAnarchy is offline
post #2 of 4 (permalink) Old 09-03-2009, 11:45 PM
dms
dms's Avatar
the yoke s transferrable. But it is critical to get the nut in the EXACT same place. Failure to do this will either reduce or increase pinion preload. you do not want to do either!
mike
dms
Michael White
DMS Doing Mike's Stuff
dms is offline
post #3 of 4 (permalink) Old 09-04-2009, 12:33 AM
AlaGreyGoat's Avatar
I may be wrong, but I thought the 04 and the 05-06 had six bolts in the rubber donut.
Three to the rearend yoke and three to the driveshaft flange. I have 2ea. 05 or 06 rearends
in the basement and the one in my 05. They all have a
3 bolt yoke on the rearend. I found that the bolt pattern is smaller diameter on the 04.
Here is a pic of an 05-06 donut.
It is the same for the front and rear.
Larry
Name:	05-06 GTO Driveshaft rear yoke with rubber.jpg
AlaGreyGoat is offline
post #4 of 4 (permalink) Old 09-04-2009, 03:53 PM
GM4life's Avatar
If you have a four bolt yoke then someone had a aftermarket DS on it before(stock is three). Do what DMS said and x-fer the yoke off your old one. Just fyi The 05-06 DS, pumpkin and CV's are different than the 04.
If it just takes swaping the yoke to get a stronger rearend on an 04 thats a good deal.
GM4life is offline
'05 GTO acting like it has an open diff 3degOfrdm Drive train, suspension, alignment and brakes. 7 11-15-2008 07:23 AM
what size stubbs, axles, driveshaft can fit stock diff? banshee 2004-2006 GTO General Discussion 2 07-29-2008 08:01 AM
Diff. pinion seal leak @ 11.5K cat1055man Drive train, suspension, alignment and brakes. 3 12-13-2007 05:27 AM
Diff just took a crap on me socal gto Drive train, suspension, alignment and brakes. 18 09-28-2006 10:52 AM
??? about diff. additive part # 89021958 Gooooat Drive train, suspension, alignment and brakes. 8 03-03-2006 10:56 PM
