T-56 transmission fluid - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-31-2018, 10:58 AM Thread Starter
Zachary Cote's Avatar
What’s the best transmission fluid I can use? I heard atf is a good one to use
Zachary Cote is offline
post #2 of 4 (permalink) Old 01-31-2018, 11:38 AM
GTO44's Avatar
Quoted: 37 Post(s)
Dex III is what it uses but the DexIII license ran out in 2006. GM changed to the GM Genuine Manual Transmission Fluid Part #88861800 .
4.6 quarts filled thru the reverse light sensor on the passenger side of the trans.
Here's a link to fluid on summit. Thats where I got mine from.
https://www.summitracing.com/parts/ADO-10-4033
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 4 (permalink) Old 01-31-2018, 03:31 PM Thread Starter
What about Dexron 6?
post #4 of 4 (permalink) Old 01-31-2018, 03:41 PM
GTO44's Avatar
Quoted: 37 Post(s)
You're free to run what ever you'd like.
The manual says GM #88861800 for GM T-56 manual transmissions. It's $6.75 a bottle. Do you really want to take a chance putting a random fluid in your trans?
I did mine a year ago and it's still smooth as butter. And I beat that absolute piss out of my car, respectfully of course
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
transmission fluid sixtysix 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 12-27-2015 03:15 PM
Automatic transmission fluid Markd15668 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-27-2015 09:30 PM
Transmission fluid Beef 66 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 10-03-2011 06:25 PM
Changed transmission fluid GM4life Drive train, suspension, alignment and brakes. 7 08-24-2011 07:35 AM
Transmission Fluid HELP!! Falco21 Service, Maintenance and Technical Discussion 6 05-26-2010 09:39 PM
