TCS Switch - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-24-2018, 12:47 PM Thread Starter
TCS Switch
I have a 1971 LeMans 350 V8 with TH350 transmission. TCS switch has been removed by previous owner and hole plugged. New wiring harness has two female spade connectors set at right angles to each other - not parallel as on all TCS switches I can find. Where can I get correct TCS switch? If not available, can I use a different two-spade connector TCS switch and modify the harness connectors? Why are there two circuits to the TCS switch?
David Bluck is offline
P0335, TCS turns off, and crank/no start or start then die. dlb1982 Service, Maintenance and Technical Discussion 2 10-13-2015 09:57 PM
ABS and TCS fault and off, help! F4LL3NBURR1T0 Service, Maintenance and Technical Discussion 3 09-05-2012 02:01 PM
What does the on/off switch do exactly? batmans 2004-2006 GTO General Discussion 11 11-15-2010 03:44 AM
Power loss at 4k rpm + TCS off... HELP MoGoThnSho 2004-2006 GTO General Discussion 6 10-03-2009 11:49 AM
Feeler: TCS Memory Module KPierson Interior Discussions 1 06-23-2006 04:05 PM
