Thinking of upgrading stock clutch? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-07-2013, 08:31 PM Thread Starter
SIXO GTO's Avatar
What clutch kit do you recommend? I have 12k miles on my 05 GTO & am getting ideas on what to upgrade to when it wears out?? ive hears the LS7 clutch / throw out / slave cylinder, flywheel from GM is a good choice but I would like to know what all of you recommend since your opinion to me is what counts with what works & what don't !!! also I will be purchasing a harrop rear diff cover/ mount to strengthen up my rear end.... I also go a set of sscs poly engine mount/ trans mount kit going in over the winter any help would be appreciated
SIXO GTO is offline
post #2 of 5 (permalink) Old 12-08-2013, 07:30 AM
SANDU002's Avatar
If you do not have power mods and do not plan to add any, then the LS7 is a good choice.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #3 of 5 (permalink) Old 12-08-2013, 09:48 AM
I agree. For sure install a remote bleeder on the slave. It makes bleeding and fluid changes so much easier and better. FWIW I have a Harrop cover and like it but it's not got a lot of bang for the buck. Intended use of the car plays a lot into what you upgrade after the basics like strut tower and front RR bushings, shocks and springs.
post #4 of 5 (permalink) Old 12-09-2013, 02:59 PM Thread Starter
SIXO GTO's Avatar
I am planning on this ... suppose be 556hp 475lbs-ft dyno results
TFS-K306-550-470
Trick Flow® 550 HP GenX® Top-End Engine Kits for GM LS2
* Pair of Trick Flow® GenX® street/strip cylinder heads
* Specially matched hydraulic roller cam
* Roller rocker arms
* Pushrods
* Head gaskets
* Head bolts
* Exhaust gaskets
* Balancer bolt
http://static.trickflow.com/global/i...70%202014c.pdf
SIXO GTO is offline
post #5 of 5 (permalink) Old 12-13-2013, 01:55 PM
NucciGOAT's Avatar
TFS-K306-550-470
* Pushrods
* Head gaskets
* Head bolts
* Exhaust gaskets
* Balancer bolt
That's an engine dyno with longtubes installed and a fast intake just so you know. That is not what you will get on a chassis dyno to the ground. And IMHO there are waaaaay better cams to be had then the one in that kit. The heads are good tho
Sent from AutoGuide.com App
2004 yellow jacket M6: AEM intake, SLP LM2, 05/06 front brakes with DBA slotted rotors & hawk pads, B&M shifter, MSD wires, NGK TR55 plugs, Diablo predator tuned..
NucciGOAT is offline
Upgrading a T-56 for more power Ktang Drive train, suspension, alignment and brakes. 6 11-04-2011 10:19 AM
Thinking of selling 04 stock exhaust. Any interest? bryan200088 Intake and Exhaust Discussions 0 03-11-2011 02:31 PM
thinking about selling stock 17 inch wheels 04torridm6 Wheels and tires 4 09-08-2009 10:14 AM
Stock Clutch Durability NosferatU Service, Maintenance and Technical Discussion 12 02-28-2009 03:20 PM
Stock clutch? MrPopular Drive train, suspension, alignment and brakes. 8 12-15-2006 03:51 AM
