tire hit right front fender well - Pontiac GTO Forum
post #1 of 14 (permalink) Old 08-26-2009, 07:06 PM Thread Starter
I guess that is what caused the fender well pull down a little and the screw is gone that is at the top of the fender well....has anyone else had this happen? what can I do to keep this from happening again?
lovin it is offline
post #2 of 14 (permalink) Old 08-27-2009, 06:55 AM
jpalamar's Avatar
Common suspension issue. Search. It has been answred too many times.
04 GTO - sold
jpalamar is offline
post #3 of 14 (permalink) Old 09-03-2009, 09:40 AM Thread Starter
Oh why didn't I think of that?? Oh, I did and didn't find anything that's why I asked....If anyone alse could please help me I would greatly appreciate it as I'm not sure if it was my tire that caused this or what!!! Thanks in advance!
lovin it is offline
post #4 of 14 (permalink) Old 09-03-2009, 10:03 AM
jpalamar's Avatar
Strub rub is a common issue is bushings failing. Upgrade to poly and you are good to go. Pedders is just 1 company that makes them. BMR is also a vender on the site and I think they make them as well.
04 GTO - sold
jpalamar is offline
post #5 of 14 (permalink) Old 09-03-2009, 10:14 AM Thread Starter
the indention is on the outside top fender wall....would strut rub have caused it there? Or are you saying the bushings are wore out and thats what made the fender come down and hit the tire?
lovin it is offline
post #6 of 14 (permalink) Old 09-03-2009, 10:21 AM
AlaGreyGoat's Avatar
What size rims and tires do you have?
Too wide of rim or wrong offset on rim can cause it.
Also, weak springs/struts.
Bad radius rod bushings can cause it to hit on the
back of the fendewell
Larry
AlaGreyGoat is offline
post #7 of 14 (permalink) Old 09-03-2009, 10:37 AM Thread Starter
Stock wheels and tires are 245/45/17....it looks like to me for it to hit on the tire at the top I must of had the wheel turned a little to the outside and hit a hole in the road for it to hit where it did and to pull the screw out....I just had these tires put on in May and the mechanic said everything looked good.....but I'm also having the vibration in steering wheel mostly around 55 to 60 mph and a little bit when I brake....I had others tell me to torque the wheels so I'm going to try that.....My husband said he thinks the indention was already there and the screw was already gone when we bought it but I think as many times as it has been washed I would have noticed it....
lovin it is offline
post #8 of 14 (permalink) Old 09-03-2009, 05:12 PM
i haven't heard of strut bushing causing fender well contact but radius rod bushings, ya. that and weak springs/struts are the other possibility
post #9 of 14 (permalink) Old 09-24-2009, 09:03 AM
Cobra126's Avatar
With the car having all OEM suspension parts in new condition, and alignment at proper specs, will I still have a problem or should I be good to go? I have the OEM 17's with original tire size.
Thank you
Cobra126 is offline
post #10 of 14 (permalink) Old 09-24-2009, 12:19 PM
GTOAA 04-06 Technical Advisor
GTOJer's Avatar
Consider going to a Pedders dealer to have it checked out. Some of the bushings on our car just can't hold up. The radius rod bushings came filled with liquid but it tends to weep out. This car was designed for a V6 but Holden shoved a V8 in theirs which is what led to us getting the GTO. So this bushing doesn't last carrying the weight of our engine and due to the fact of all of our great roads. I am not telling you to go get Pedderized, I'm just saying your car will handle so much better and not effect your ride quality if a few of the bushings are upgraded.
Jerry
GTOAA '04-'06 Technical Advisor
My Shop
KPE - Klaus Performance Engineering
2004 Pontiac GTO 6.7/M6/Barbados Blue (1 of 271) My Car Page
Featured in the April 2007 High Performance Pontiac Magazine
GTOJer is offline
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Discount Tire Announces New 2009 Driver for FormulaD Discount Tire In the News 0 11-18-2008 02:22 PM
Identifying Tires: Production Date, Speed Rating, & Load Range GTO JUDGE Wheels and tires 0 05-10-2008 06:53 AM
Strange issue with Flat tire at Dealership. GTOtbird Service, Maintenance and Technical Discussion 7 12-30-2006 01:22 PM
