tire rubbing.....with a twist...help! - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-02-2009, 02:13 PM Thread Starter
rextheracer's Avatar
Send a message via AIM to rextheracer
so i have 18x9's on the rear of my 06 gto....has 265 tires....i go to get the fenders rolled because the tire was rubbing whenever i had people in the back of the car/go over larger bumps in the road....after i get the goat to the shop, they inform me that the fender has been cut w/ a welder and nothing can be rolled....so i left, with nothing done.....im thinking drag bags might be the answer.....i would say id get smaller tires, but their brand new.....so should i g with the drag bags? or is there an alt. route?
rextheracer is offline
post #2 of 7 (permalink) Old 06-02-2009, 03:03 PM
Sounds like some springs would work out better than drag bags. Give these people a call. They are Pedders dealers.
Carolina Auto Masters
GTOsarge is offline
post #3 of 7 (permalink) Old 06-02-2009, 03:34 PM Thread Starter
thanks for the help....the only things im worried about are that if the coils arent tight enough, and the price....the drag bags are adjustable, so i wouldnt have to worry about messing that up....that or someone told me bump stops would work....it just seems like this shouldnt be a costley problem to fix......ugh....
post #4 of 7 (permalink) Old 06-02-2009, 04:46 PM
Get lighter friends.
post #5 of 7 (permalink) Old 06-03-2009, 03:35 PM
Hello, drag bags will help stiffen the rear and will slightly raise it as well. Give me a call if you need a set.
Thanks,
Joe Kubiak
Sales / Tech
BMR Fabrication
813-986-9302 Phone
813-986-8055 Fax
[email protected]
www.BMRFabrication.com
BMR Sales is offline
post #6 of 7 (permalink) Old 06-04-2009, 12:39 PM
I went the Pedders route with the 5/8" no drop and inserts.
I run 18x 9.5 275's no fender rolling. I only get a rub on a severe bump in the road.
Pedders also has a 1" lift coil spring. That may be what you need.
rtviper is offline
post #7 of 7 (permalink) Old 06-05-2009, 06:25 PM Thread Starter
i ordered some spring expanders (at least i think thats what theyre called cause my good friend is with an autoparts store and hooked me up)
thanks for the advice everyone, ill let you know if it works out..
1 of 104
qsm/red/m6/17's
K&N only
355rwhp
361ft/lbs
"Horsepower is how fast you hit the wall
Torque is how far you carry the wall"
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Discount Tire Announces New 2009 Driver for FormulaD Discount Tire In the News 0 11-18-2008 02:22 PM
Identifying Tires: Production Date, Speed Rating, & Load Range GTO JUDGE Wheels and tires 0 05-10-2008 06:53 AM
Strange issue with Flat tire at Dealership. GTOtbird Service, Maintenance and Technical Discussion 7 12-30-2006 01:22 PM
