Tranny Noise - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-10-2009, 03:33 PM Thread Starter
Tranny Noise
New owner of an 05 LS2 six speed with just over 9K on the clock. Is it normal to hear "clunking" when light loading from first to second? Still hear it in third and forth when driving "normally" but not as noticable. I am asking because my wife who usually drives a 06 Charger R/T is saying something is wrong when she drives it--sounds like a tough truck tranny to me;; so it doesnt bother me, but just want to make sure. I think it's really the shifter that's causing the problems--I hate the throw on the stock shifter and with that stupid 1st to 4th kicking in every once in a while (never really seem to know when) you just cant get used to it. There has got to be a wire that you can disconnect or cut to disable that stupid thing??? Any experiance / advice appreciated.
Kirk
khurst is offline
post #2 of 3 (permalink) Old 12-10-2009, 03:50 PM
jpalamar's Avatar
SLP sells a skip shift kit that is like $30 that will solve your problem. Or a tuner can tune your car and remove the 1-4 shift. The 1-4 shift was GM's way of not having a gas guzzler tax on their manual transmission.
As far as the trans, even with low miles oils are only good so long. I was change your trans fluid. I went with Royal Purple with Syncromesh(4.6+- quarts needed) and did Royal Purple 75W140(1.6+- quarts needed) with friction modifier to my rear diff. Clucking can be something failing, but I bet some fresh fluids would do wonders. My car has always been loud compared to others I've ownebed, but I think it is normal.
Shifter does suck stock. There are a few shifters out there and they are by far the bes tmod you can do to the car. I like the GMM Ripshifter but its pricy.
04 GTO - sold
jpalamar is offline
post #3 of 3 (permalink) Old 12-11-2009, 01:34 AM
87GN06GTO07IRL's Avatar
That clunk could come from a lot of places. look at how much your shifter will move when changing gears. that means your motor and trans are moving that much and it will get louder as the already horrible mounts get worse. poly motor and trans mounts will fix that. our cars have a two piece drive shaft that can also cause the clunk.
87GN06GTO07IRL is offline
3M Window Weld for Tranny Mount gurvinerjeff Engine Discussions 3 07-10-2009 12:05 PM
Rubbing Noise From Rear??? pwned 2004-2006 GTO General Discussion 29 05-28-2009 12:00 AM
tranny noise/questions MacPro Drive train, suspension, alignment and brakes. 4 11-12-2008 05:20 AM
Noise from rear... Justice Service, Maintenance and Technical Discussion 0 07-10-2006 04:20 PM
04 GTO tranny noise GTOgator Drive train, suspension, alignment and brakes. 2 11-07-2005 03:11 PM
