Urethane Bushings ........ - Pontiac GTO Forum
post #1 of 16 (permalink) Old 12-14-2005, 11:09 PM Thread Starter
johnebgoode's Avatar
Was reading service manual regarding the remounting of the rear suspension cradle after dropping it for bushing installation. It states that new bolts are required. After torque spec of 96 ft.lbs. is achieved, an addl turn is needed and an angle meter is required to achieve an addl.40 degrees to finalize the job. I will post part # for tool and bolts that is specified in manual when I get back to work in morning. Has anyone done this or are you just re attaching sub frame ? How critical is this procedure?
johnebgoode is offline
post #2 of 16 (permalink) Old 12-15-2005, 08:34 AM Thread Starter
OK ....its Thurs morning......part # for bolts is 92038482 and # for angle meter is J45059 as described in service manual.
post #3 of 16 (permalink) Old 12-15-2005, 08:58 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
are you going to do the install yourself?
post #4 of 16 (permalink) Old 12-15-2005, 09:05 AM Thread Starter
Was planning to........
post #5 of 16 (permalink) Old 12-15-2005, 09:09 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
two key words to remember:
jackstands
patience
post #6 of 16 (permalink) Old 12-15-2005, 09:50 AM
woof. Good luck. That is not a fun mod to do yourself.
dealernut is offline
post #7 of 16 (permalink) Old 12-15-2005, 09:56 AM
We've done these a few times, it's really not that big of a deal and shouldn't take you more than a couple of hours, alone and on your back at home. The important part is to make sure you get the correct torque, we didn't use the J-tool to do it and we've NEVER had a problem, and I really don't think it's necassary to replace the bolts. Just keep in mind that these are the same people (GM) that say to pull the motor to replace the cam.....
GTODEALER is offline
post #8 of 16 (permalink) Old 12-15-2005, 09:56 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
he should be ok though.
post #9 of 16 (permalink) Old 12-15-2005, 10:03 AM Thread Starter
Will be dooin it at the shop on lift. ALready have the bolts. ty
post #10 of 16 (permalink) Old 12-15-2005, 10:05 AM
Should be super simple on a lift..... around 45 minutes!
