Vibration under acceleration?? Please Help!! - Pontiac GTO Forum
post #1 of 10 (permalink) Old 01-21-2010, 09:23 PM Thread Starter
I had my car to the dealership a couple weeks ago to have the tailshaft housing replaced. Ever since then I noticed a vibration in the shifter and you can feel it in the whole car. Its mostly in 3rd and 4th under heavy acceleration. I'm wondering if the tranny could be lose or if it is something in the driveshaft. Has anyone had that before?? Please help!!
RedGoat_05 is offline
post #2 of 10 (permalink) Old 01-21-2010, 09:36 PM
Justice's Avatar
Send a message via Yahoo to Justice
The driveline coupler uses crush sleeve type lock nuts. These lock nuts can only be torqued ONCE. If they are ever removed, they have to be replaced with new ones. I've only found these in a bolt kit for the coupler and they retail for about $85 for a bolt and nut set.
I had a dealer do a clutch job on my GTO, and re-used the nuts. The rear coupler started vibrating and damaged the front pinion deal and bearing on my diff. They denied they caused the damage. I'm in need of a $3500 rear end in my car because 3 lock nuts were re-used.
"Some people are like slinky's. They really have no useful purpose, but they can still put a smile on your face when you push them down stairs."
Justice is offline
post #3 of 10 (permalink) Old 01-22-2010, 02:44 AM
Daymm that awful. Where exactly are these luck nuts at? Outside of the donuts on the driveshaft?
MTUGTO is offline
post #4 of 10 (permalink) Old 01-23-2010, 10:34 AM
Justice's Avatar
Kinda, yes. There is a step by step article on replacing a clutch on the High Performance Pontiac website. Some good pics there. Google should be able to turn up some good pics for you.
Justice is offline
post #5 of 10 (permalink) Old 01-23-2010, 03:41 PM
AlaGreyGoat's Avatar
Check eBay or contact Seller: fparts if you need a rearend.
I have two spares in my basement I got for less than $200
each.
Also, there have been tons of people who have reused
these nuts and bolt without any problems.
Larry
AlaGreyGoat is offline
post #6 of 10 (permalink) Old 01-23-2010, 08:00 PM
Justice's Avatar
And that's great that they can re-used a damaged nut and have no ill effects. I wasn't even aware of those type of lock nuts being used until I had the car in for a rear area vibration at speed. Then it was pointed out to me that I had a loose connection at the coupler and it had damaged the front pinion seal and bearing.
And thank you for the information about rear's on ebay! I will definitely be looking into that! I only quoted $3500 because that's what the dealer shop supervisor had told me. I knew I could get them cheaper elsewhere... it was the sting of the dealer telling me that the damage was caused by them, and they weren't going to fix it that irked me.
Justice is offline
post #7 of 10 (permalink) Old 01-24-2010, 01:47 AM
Almost all the nuts and bolts on the GTO's suspension and undercarriage are the TTY type,
for one use only. I don't understand the loose bolts on the rubber donut coupling causing the
pinion seal and bearing failure. I've seen the rubber coupling tear at the metal thru tubes and
vibrate, but never cause this failure. Now, if someone loosened or changed the yoke on the
differential and didn't replace that crush tube, well that's another story.
Larry
post #8 of 10 (permalink) Old 01-24-2010, 10:16 AM
bwiest's Avatar
I would recommend always replacing the bolts. It might cost a bit more, but bolts are only ever designed to be loaded once if you intend it to keep the strength characteristics of that bolt. Any subsequent re-use significantly reduces the overall capabilities of any bolt or nut. Just my $0.02
bwiest is offline
post #9 of 10 (permalink) Old 01-24-2010, 10:41 AM
Gotagoat's Avatar
Good thread, good info; but, damn, Justice, your avatar is distracting. (Don't change it though.)
Gotagoat is offline
post #10 of 10 (permalink) Old 12-13-2010, 07:10 PM
I had an issue with vibration on acceleration. The vibration started at roughly 20 MPH and got more violent under heavy acceleration. This would happen in all gears. The vibration would decrease while costing in neutral or spooling down in gear. Found out that I was missing a bolt in the front joint of the drive shaft. I had a new Centerforce dual friction clutch installed 4K miles previously to this issue. Hope this helps.
joesykora is offline
Slight Vibration? ctdkid 2004-2006 GTO General Discussion 7 01-23-2010 10:28 AM
Slight Vibration? ctdkid Drive train, suspension, alignment and brakes. 4 10-17-2009 09:15 AM
poor acceleration problems koman The Lounge 25 01-14-2007 10:19 AM
Question about hard acceleration SDMF Jon 2004-2006 GTO General Discussion 28 12-10-2004 11:56 AM
Engine Vibration DrFix2Fly Service, Maintenance and Technical Discussion 19 11-23-2004 10:43 PM
